![]() | Home > Puma (Tdci) > Rear Shock Absorbers. |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2724 ![]() ![]() |
From some time early in the Td5 run they changed the rubbers/washers arrangement at the lower end of the rear shocks. I presume the pin length is different to account for this, although usually aftermarket shocks require reverting to the earlier setup on later vehicles.
Mjibex Member Since: 21 Mar 2013 Location: Reading Posts: 288 ![]() ![]() ![]() |
Thanks for the speedy reply - so I could likely “bodge/make” the cheaper option work then..
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 870 ![]() ![]() |
I don't know if the pin length is different.I don't see why, it still fits the same, just the number of washers needed is different. |
I’ve assumed that it is the case because when I’ve on one occasion tried to fit the wrong type the pin was too short to reach through the later thicker bushes.
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3531 ![]() ![]() ![]() |
Had the same as Retroanaconda. Perhaps some variation between makes? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
I’ve taken the plunge and ordered the cheaper pair - I’ll see what happens!!! MOT at 11.5 years old (COVID messed timings up a bit!!!) - has mentioned a few rubber bits are not A1 (rear shock bushes included)…
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Take the bush cups off the axles if you have them (usually they’re spot welds) and it won’t matter. They wreck the bushes in my opinion anyway.
All fitted with no issues (didn’t remove the cups - as done on the drive with limited tools).
All fitted fine and the improvement is 👍👍👍 Far less clonks.. I should have done this a few years ago.. |
