Home > Puma (Tdci) > Rear Shock Absorbers.
Mjibex
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Loire Blue
Evening Everyone,
I am looking for some clarity on the below - I appreciate people may have views on alternatives/better options; but I am just looking for the answer to below.
Can anyone help with what the difference would be (if anything) - I appreciate it is a VIN range difference. I have a 2103 2.2 110 - but am struggling to understand the real world difference.
Part numbers are the same (bar “TD5”) - but what actual (if any) difference is there/could there be?
Mark.
Post #1060876 18th Feb 2025 9:02pm
Retroanaconda
From some time early in the Td5 run they changed the rubbers/washers arrangement at the lower end of the rear shocks. I presume the pin length is different to account for this, although usually aftermarket shocks require reverting to the earlier setup on later vehicles.
Post #1060877 18th Feb 2025 9:06pm
Mjibex
Thanks for the speedy reply - so I could likely “bodge/make” the cheaper option work then..
Post #1060878 18th Feb 2025 9:20pm
Chicken Drumstick
I don't know if the pin length is different.I don't see why, it still fits the same, just the number of washers needed is different.
Post #1060879 18th Feb 2025 9:27pm
Retroanaconda
I’ve assumed that it is the case because when I’ve on one occasion tried to fit the wrong type the pin was too short to reach through the later thicker bushes.
Post #1060884 18th Feb 2025 9:59pm
Dinnu
Had the same as Retroanaconda. Perhaps some variation between makes? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1060893 18th Feb 2025 10:39pm
Mjibex
I’ve taken the plunge and ordered the cheaper pair - I’ll see what happens!!! MOT at 11.5 years old (COVID messed timings up a bit!!!) - has mentioned a few rubber bits are not A1 (rear shock bushes included)…
Post #1060900 18th Feb 2025 11:35pm
NickMc
Take the bush cups off the axles if you have them (usually they’re spot welds) and it won’t matter. They wreck the bushes in my opinion anyway.
Post #1060903 19th Feb 2025 12:33am
Mjibex
All fitted with no issues (didn’t remove the cups - as done on the drive with limited tools).
All fitted fine and the improvement is 👍👍👍 Far less clonks.. I should have done this a few years ago..
Post #1061367 25th Feb 2025 8:30pm
