Home > General & Technical (L663) > Engine idle timer
ElectroGeek
United States
Engine idle timer
Dose anyone know what CCF needs to be changed to stop the engine idle timer? I need it to idle as long as I want as I leave my dog in the car during the summer for a hour.
Post #1060869 18th Feb 2025 5:40pm
CincyRovers1
United States
I'd just use the remote app to pre-condition the cabin. Ut stays on for a maximum of 30 minutes, but you can just fire it up again. 𝟐𝟎𝟐𝟏 𝐃𝐞𝐟𝐞𝐧𝐝𝐞𝐫 𝟏𝟏𝟎 𝐒 𝐏𝟑𝟎𝟎 (Pangea Green over Acorn/Lunar)
𝟐𝟎𝟐𝟑 𝐏𝐨𝐫𝐬𝐜𝐡𝐞 𝐌𝐚𝐜𝐚𝐧 𝐒 (Dolomite Silver over Black/Bordeaux Red)
𝟐𝟎𝟏𝟕 𝐃𝐢𝐬𝐜𝐨𝐯𝐞𝐫𝐲 𝐇𝐒𝐄 𝐋𝐮𝐱𝐮𝐫𝐲 𝐒𝐢𝟔 (Aintree Green over Vintage Tan/Ebony) - Gone
𝟐𝟎𝟏𝟏 𝐋𝐑𝟒 𝐇𝐒𝐄 𝟓.𝟎 (Ipanema Sand over Almond/Arabica) - Gone
Post #1060927 19th Feb 2025 2:04pm
pjeski
United States
I can't remote start mine again after the 30 minutes is up, unless I do a normal start. If I stop it with, say, 10 minutes left, I can remote start it a second time for 10 minutes max.
Post #1060933 19th Feb 2025 3:43pm
ElectroGeek
United States
There has to be a CCF that you can modify to extend or remove this function.
Post #1060934 19th Feb 2025 3:45pm
PNW Rover
United States
It only lets you fire it up remotely once. One of my many issues with LR remote start.
Take any most GM vehicles like Escalade, Yukon, etc. With those vehicles when you push the start button and continue to hold it, after a few seconds a message is displayed stating auto-shutdown is disable. Not only will the vehicle idle until it runs out of fuel but you can also exit the vehicle and lock it with your key fob. The other cool feature is you can kit a button on your way out that turns off the interior motion sensor, so your pups not only remain cool or warm but they are secured in the alarmed vehicle with not worry of a motion sensor going off.
@cincyrovers you've stated you have contacts at JLR engineering. They really need to up their remote start game. I'd be happy to chat with someone one day about all of the easy features that are a short software programming time away.
Post #1060938 19th Feb 2025 4:54pm
XplusYplusZ
Same here.. The pre-conditioning is 30 mins max then it shuts down, and you can't remotely restart it again unless you have a proper driving cycle in between remote start-ups. I assume this might be linked to global climate legislations..
Worst case, I guess you could pop a brick on the brake and install one of these badboys.. Laughing
https://www.amazon.co.uk/JAOGAUS-Smart-Swi...mp;sr=8-46
Post #1061018 21st Feb 2025 9:13am
