2011 130" single cab load question.
I was helping a friend with some minor details on his 130" camper. Weight test shows 3.1 Ton total, including 2 adults and some gear plus fuel and water etc (Front: 1.05 Ton and Rear 2.04 Ton)
Bumpstop distance on all 4 corners are as the vehicle has no extra load on it. Std 130" suspension showing 16 cm at the rear and 10.6 cm at the front. Am I missing something?
Click image to enlargePuma 110" SW
17th Feb 2025 11:38pm
I'm not sure what you are actually asking...
18th Feb 2025 9:53am
MK
This 130" with quite a bit of load does not sag.Puma 110" SW
