2011 130" single cab load question.
I was helping a friend with some minor details on his 130" camper. Weight test shows 3.1 Ton total, including 2 adults and some gear plus fuel and water etc (Front: 1.05 Ton and Rear 2.04 Ton)
Bumpstop distance on all 4 corners are as the vehicle has no extra load on it. Std 130" suspension showing 16 cm at the rear and 10.6 cm at the front. Am I missing something?
Click image to enlargePuma 110" SW
18th Feb 2025 12:38am
I'm not sure what you are actually asking...
18th Feb 2025 10:53am
MK
This 130" with quite a bit of load does not sag.Puma 110" SW
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
