![]() | Home > Technical > 2015 Defender 90 - Momo Competition steering wheel |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20613 ![]() ![]() |
Looks good.
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1443 ![]() ![]() ![]() |
That does look good and you've done a great job of repositioning the holes.
There are 2 versions of the Slimline Boss, for Momo 70mm PCD or Startech (74mm??) The boss you had appears to be the Startech version. https://www.optimill-uk.com/interior-parts...-boss.html |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2137 ![]() ![]() |
I’m assuming as yours is a 2015 Puma you will have DSC. If so hopefully you did not disturb the steering angle sensor, else you will get strange behaviour when turning or/and dash light coming up.
Marty008 Member Since: 10 Jun 2024 Location: Luzern Posts: 10 ![]() ![]() ![]() |
Hi Ianh,
You are correct I have this angle sensor mounted on the frame of the assembly - when performing the drilling I paid attention to have the two grooves as horizontal as possible, similar to the JLR steering wheel. So far it is fine - I still have sometimes turning right a self cancellation but after a few turns all good. Do you know the aim of this steering wheel sensor - what it is used for ?! Cheers |
The steering angle sensor is part of the Dynamic Stability Control system, first fitted on 2015 MY vehicles.
