Home > General & Technical (L663) > Cold Feet
Jimmyh
Cold Feet
I’m new to my 2023 X Dynamic SE no-wrap Trophy. I find two things here on cold mornings. The temperature isn’t maintained so consistently: I find I turn up high >80 to get warm then down ~70 to maintain. I might expect I set the temp and goes there as it can and stays.
Then I also find my feet are never getting much from the system long after my upper body is warm. Even when choosing footwell only on the vertical range selector (I doubt it’s called that). As though the fan or valve to that area is not open or adequate.
I wonder if others have similar experiences?
Thanks
Post #1059816 7th Feb 2025 3:05pm
CincyRovers1
United States
Is auto climate on? If so, click the "auto" button so it isn't lit up orange. Auto climate doesn't heat up very quickly. If its cold when I leave my office, I always set the temperature to "hi" until it warms up, then set it back down to my desired temperature with auto climate on to keep the windows from fogging up. 𝟐𝟎𝟐𝟏 𝐃𝐞𝐟𝐞𝐧𝐝𝐞𝐫 𝟏𝟏𝟎 𝐒 𝐏𝟑𝟎𝟎 (Pangea Green over Acorn/Lunar)
𝟐𝟎𝟐𝟑 𝐏𝐨𝐫𝐬𝐜𝐡𝐞 𝐌𝐚𝐜𝐚𝐧 𝐒 (Dolomite Silver over Black/Bordeaux Red)
𝟐𝟎𝟏𝟕 𝐃𝐢𝐬𝐜𝐨𝐯𝐞𝐫𝐲 𝐇𝐒𝐄 𝐋𝐮𝐱𝐮𝐫𝐲 𝐒𝐢𝟔 (Aintree Green over Vintage Tan/Ebony) - Gone
𝟐𝟎𝟏𝟏 𝐋𝐑𝟒 𝐇𝐒𝐄 𝟓.𝟎 (Ipanema Sand over Almond/Arabica) - Gone
Post #1059837 7th Feb 2025 5:50pm
Jimmyh
Thanks good to know. Yes I tried of course auto/direct fan control/setting temp to ‘Hi’
I’d still conclude the portion to the foot well is low. I noticed that when setting to foot well only the rear vents on the back of the arm rests are closed. Maybe there is a foot vent for the rear? I have to check.
Post #1059848 7th Feb 2025 6:59pm
lightning
l also find that when you set to "AUTO" the heat initially comes more from the centre vents and not much to the feet.
lf l set manually there is not much air through the footwell vents even when set to "footwell only" unless
the fan is turned up to 4 or 5 and then it's quite noisy.
lt works better if you close the centre vents in the middle of the dashboard.
Post #1059869 7th Feb 2025 8:45pm
