![]() | Home > General & Technical (L663) > Cold Feet |
CincyRovers1 Member Since: 30 Nov 2023 Location: Cincinnati, Ohio Posts: 128 ![]() ![]() |
Is auto climate on? If so, click the "auto" button so it isn't lit up orange. Auto climate doesn't heat up very quickly. If its cold when I leave my office, I always set the temperature to "hi" until it warms up, then set it back down to my desired temperature with auto climate on to keep the windows from fogging up. ๐๐๐๐ ๐๐๐๐๐ง๐๐๐ซ ๐๐๐ ๐ ๐๐๐๐ (Pangea Green over Acorn/Lunar)
๐๐๐๐ ๐๐จ๐ซ๐ฌ๐๐ก๐ ๐๐๐๐๐ง ๐ (Dolomite Silver over Black/Bordeaux Red) ๐๐๐๐ ๐๐ข๐ฌ๐๐จ๐ฏ๐๐ซ๐ฒ ๐๐๐ ๐๐ฎ๐ฑ๐ฎ๐ซ๐ฒ ๐๐ข๐ (Aintree Green over Vintage Tan/Ebony) - Gone ๐๐๐๐ ๐๐๐ ๐๐๐ ๐.๐ (Ipanema Sand over Almond/Arabica) - Gone |
Jimmyh Member Since: 06 Feb 2025 Location: Colorado Posts: 2 ![]() ![]() |
Thanks good to know. Yes I tried of course auto/direct fan control/setting temp to โHiโ
Iโd still conclude the portion to the foot well is low. I noticed that when setting to foot well only the rear vents on the back of the arm rests are closed. Maybe there is a foot vent for the rear? I have to check. |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3052 ![]() ![]() |
l also find that when you set to "AUTO" the heat initially comes more from the centre vents and not much to the feet.
lf l set manually there is not much air through the footwell vents even when set to "footwell only" unless the fan is turned up to 4 or 5 and then it's quite noisy. lt works better if you close the centre vents in the middle of the dashboard. |
