Home > Puma (Tdci) > Steering Dampers. Adjustable vs Standard.
TriniDaddy
2008 Defender 110 Puma 2.4 XS CSW Arles Blue
Hey. Anyone used the TF 4 Stage Adjustable Steering Damper TF833?
Is there really an advantage to changing the settings or is it unnecessary?
And where does the dial face? Wouldn't want to be out doing something and it gets knocked off... 110 SW 2.4
IZUMI BLUE
Post #1059679 6th Feb 2025 2:37pm
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
It's said that if the suspension and steering system is set up we'll that a damper isn't needed. Having said that I'd like to try one with a different damper to see if it's , well, any different. My old 110 had two fitted and on removing one it shook like mad until I tightened up the swivel pins to the correct amount, then it was fine, so clearly didn't need two. 1983 110 automatic OM606
Post #1059687 6th Feb 2025 3:23pm
Chicken Drumstick
I’d have thought it’s just make the steering heavier.
It’s not as if the steering damper moves back and forth like a shock on the axle. There is relatively little movement. Maybe if you have huge tyres like 37-40” then more damping may help control the mass. But I struggle to really see the point of upgraded steering dampers, let alone adjustable ones. I’d guess their main purpose is to lighten people’s wallets! Very Happy
Post #1059728 6th Feb 2025 9:14pm
