Home > eBay & Bargain Spots > Superwinch Husky-compatible winch bumper
jackdaniel
Australia
Not mine but found on Gumtree UK
https://www.gumtree.com/p/car-part-accesso...1478600257
Superwinch Husky compatibility is evidenced by the 4-hole Fairlead mounting pattern but would recommend confirming dimensions with the seller to be safe.
Winch dimensions:
https://www.bandcwinches.com.au/persistent...ation2.pdf
Post #1059645 6th Feb 2025 2:52am
After looking carefully at the photos I don't think it is and I don't think a Husky would fit.
The holes for the fairlead are not correctly centred round the slot, the slot is too close to the base mounting surface, and the usual clearance holes for the motor earth connection and the front motor bearing are absent.
Whilst superficially it resembles the traditional Mantec Husky bumper, on closer inspection in addition to the above it lacks the reinforcement and supplementary securing points on the bottom of the tray that the Mantec bumpers have, also the front face is not flat which definitely means the motor will foul the front plate.
The seller says he thinks it is a Britpart bumper so it could be almost anything, but I am sure a Husky wouldn't actually fit.
The photo below is the front of a genuine Mantec Husky bumper to highlight the correct layout and location of the cable slot and fairlead mounting holes.
Post #1059658 6th Feb 2025 10:19am
