Superwinch Husky compatibility is evidenced by the 4-hole Fairlead mounting pattern but would recommend confirming dimensions with the seller to be safe.
After looking carefully at the photos I don't think it is and I don't think a Husky would fit.
The holes for the fairlead are not correctly centred round the slot, the slot is too close to the base mounting surface, and the usual clearance holes for the motor earth connection and the front motor bearing are absent.
Whilst superficially it resembles the traditional Mantec Husky bumper, on closer inspection in addition to the above it lacks the reinforcement and supplementary securing points on the bottom of the tray that the Mantec bumpers have, also the front face is not flat which definitely means the motor will foul the front plate.
The seller says he thinks it is a Britpart bumper so it could be almost anything, but I am sure a Husky wouldn't actually fit.
The photo below is the front of a genuine Mantec Husky bumper to highlight the correct layout and location of the cable slot and fairlead mounting holes.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
