Home > Puma (Tdci) > Puma 2.4 blue smoke
Page 1 of 3 123>
lbdmp
France 2010 Defender 110 Puma 2.4 SW Nato Green
Puma 2.4 blue smoke
My Defender, a 2010 Puma 2.4 model with 42,000 miles, has been broken down for several months.
My problem started suddenly with the appearance of blue smoke from the exhaust.
On the advice of others, I decided to replace the injector seals and the rocker cover seals. Unpleasant surprise on dismantling, the exhaust camshaft came loose (as shown on the picture), and a rocker arm (cyl4) fell into the cylinder head causing quite a bit of damage.
https://www.defender2.net/gallery/albums/u...G_4582.jpg
I decided to dismantle the cylinder head to replace it, but on dismantling the cylinder wall (cyl3) showed a strange mark.
The decision was made to replace the engine with a second-hand one, so we put it back together, started it up, coded the injectors and learned how to inject.
A short test drive, 5 miles and the Defender starts smoking again.
I've tried again since then, and it smokes even when the engine is cold.
The problem persists despite having done :
2x turbocharger
Injector seals
Test injectors -> one had a low flow so I replaced all 4 with new ones (original)
Glow plugs + intake pipe cleaning
Compression test ok
Clean sensors, MAP & MAF (also smokes with flow meter disconnected)
No fault found on diagnosis. I'm completely lost, is the smoke coming from a problem on the new engine... or from a component that hasn't been replaced...?
Thank you in advance for your help
G&M
Post #1059211 1st Feb 2025 10:29pm
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
Blue smoke from an engine is usually a sign that the engine is burning oil. One fault that can cause this is worn piston rings. You say that you have already done a compression / leak down test on each cylinder?
When did the replacement engine come from and did you fit it yourself? If its a guaranteed unit fitted by a garage then I would be speaking to the company that rebuilt the engine.
Jim
Post #1059229 2nd Feb 2025 4:31am
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
Mine blows blue when cold. Doesn't burn a drop of oil.
Post #1059230 2nd Feb 2025 7:31am
andy63
Re: Puma 2.4 blue smoke
2x turbocharger
Injector seals
Compression test ok
G&M
Do you have working egr on it...?
And is it mapped?
Post #1059235 2nd Feb 2025 9:45am
lbdmp
Jim
Thanks for your reply. It's a second-hand engine that I fitted myself. The engine has 33,000 miles on it.
Yes I did the compression test which was positive (377 psi {26 bar} per cylinder)
Post #1059237 2nd Feb 2025 9:54am
lbdmp
And is it mapped?
It is not mapped.
The egr is activated, I've tried unplugging it to keep it closed but the result is the same.
Post #1059240 2nd Feb 2025 10:06am
lbdmp
Strange. Ours also smokes a lot when hot and we don't dare drive for fear of causing major damage.
Post #1059242 2nd Feb 2025 10:10am
What year is the engine and why was it removed from its original vehicle?
Post #1059246 2nd Feb 2025 10:22am
andy63
lbdmp wrote:
And is it mapped?
It is not mapped.
But it could be stuck open or partially, and that could give you a richer than normal charge and the smoke..
Just a thought..👍
Post #1059248 2nd Feb 2025 10:22am
lbdmp
The engine was manufactured in 2009. It comes from an accident vehicle.
Post #1059251 2nd Feb 2025 10:30am
lbdmp
andy63 wrote:
lbdmp wrote:
And is it mapped?
It is not mapped.
Just a thought..👍
I think it's a good idea. Do you know if I can use a shutter plate to try it out?
Post #1059252 2nd Feb 2025 10:32am
bear100
mine has blown blue from cold for a number of years, i think is to do with the injector seats? 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #1059257 2nd Feb 2025 10:59am
It is common, almost normal, for a cold 2.4 to produce blueish smoke on startup and this is generally not something to worry about. It shouldn't do it when warm or hot though.
I don't think a stuck-open EGR would cause blue smoke and it would produce DTCs.
A 2009 engine could conceivably suffer from the PCJ hysteresis problem which causes destructive wear to bores and pistons. Do you have any evidence to make you believe it was running clean before its accident? What happens if you remove the oil filler cap with the engine running?
I would suggest a compression test would be a sensible next step, and taking a look at the bores with an endoscope through the injector holes. Alternatively take the head off for an inspection.
Post #1059261 2nd Feb 2025 11:51am
andy63
Hmmm well I'll be at odds with bw..
If your egr valve was allowing loss of air it could well produce smoke...but Id still be inclined to get a smoke test done just to make sure the inlet side is tight..
Yes I would expect codes if its severe enough..but at least the egr is common to both engines producing the same symptoms so seems like a good place to start given its one of the few items not mentioned in the previous comments..
I thought the op had already got compression test results that were good??
Post #1059262 2nd Feb 2025 12:05pm
Yes, missed the bit about the compression test! Embarassed
Is the inside of the inlet manifold oily? Is the intercooler full of oil from the old engine?
Post #1059264 2nd Feb 2025 12:42pm
Page 1 of 3 123>
