Home > Td5 > Engine hesitates when going into neutral
MK
Probably this topic has been discussed. I am not very familiar with the Td5 engine.
Symptom. Under load or at high idle the engine runs alright. It is only when rpms drop to idle, it hesistates for 1-2 seconds. It feels like a misfire.
So those gents familiar with this loom may suggest where to start. Thanks in advance. Puma 110" SW
Post #1058540 25th Jan 2025 12:33pm
TexasRover
You mean as the rpm drop down to idle speed it seems to dip and then pick up again?
The Td5 cuts all fuel on over run and then picks up the fuel again at idle speed. This can sound a little its hesitating, but once you get used to it you don't notice it, assuming obviously it does not stall.
Personally I quite like to sound as it really enforces the 'I am now idling and oh by the way - it's rocksteady' feeling compared to say petrol engines where the rpms just drop off with no distinctive moment where it's idling.
Post #1058564 25th Jan 2025 4:19pm
landy andy
Agree. I would say what you are explaining is normal behaviour
Post #1058570 25th Jan 2025 4:38pm
MK
no, I mean once it reaches back to idle speed and after 1-2 seconds I can feel the hesitation/vibration. Then it comes back to steady idle right away. Resembles a little misfire in one or two consecutive injection. Puma 110" SW
Post #1058572 25th Jan 2025 4:41pm
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
check if the ECU receives road speed information.
contrary to what people believe that only the disco uses road speed info, the defender also uses it. The defender has migrated, leaving the owner behind.
Post #1058640 26th Jan 2025 10:50am
miker916
Scotland 2005 Defender 90 Td5 HT Belize Green
I asked exactly the same question when i first got my TD5, consensus is its perfectly normal.
https://www.defender2.net/forum/topic94365.html
Mike
Post #1061408 26th Feb 2025 8:54am
