Home > Td5 > best Full poly bush kit for a 2005 110 TD5 recommendations
maranellohouse
United Kingdom 2005 Defender 110 Td5 XS CSW Java Black
Hi all. Got a serious death wobble with the steering at 50 mph last week (damn near pulled the steering wheel out of my hand) and I know it's not the damper as it was recently replaced so it's time to replace all the bushes. I'm going to do front and rear at the same time. Can I ask what full kit you guys recommend please.
Thanks in advance, Stuart 05 Alive tuned TD5 110 Defender
73 Fiat 500 F
53 Massey Ferguson TVO
92 Kawasaki ZZR 600
97 Ferrari 456GT
www.maranellohouse.com
Post #1058447 24th Jan 2025 2:30pm
Ianh
Given there does not seem to be a source of the original quality Metalastic bushes the go to bushes now seem to be Superpro poly bushes. See https://gwynlewis4x4.co.uk/product-categor...0-110-130/
Post #1058448 24th Jan 2025 2:43pm
rustandoil
Death wobble more likely to be caused by swivel pin preload.... As for bushes, I've just fitted SuperPro from Gwyn Lewis.... Very happy
Post #1058449 24th Jan 2025 2:45pm
maranellohouse
I'll look into that.
Thanks guys for the quick response. Thumbs Up 05 Alive tuned TD5 110 Defender
73 Fiat 500 F
92 Kawasaki ZZR 600
97 Ferrari 456GT
Post #1058451 24th Jan 2025 2:58pm
ickle
+1 for Super Pro!
On reassembly use masses of MilSpec / Dinitrol / copper slip on every bolt / fixing and bracket, make it easier in 80k to do it again!
HTH Keith
Post #1058452 24th Jan 2025 3:11pm
mark1200
England 2004 Defender 90 Td5 HT Caledonian Blue
Another thing to consider is the state of your wheel bearings too as this can also cause wheel wobble, do you know when they were last changed ?
Post #1058466 24th Jan 2025 4:10pm
landy andy
SuperPro from Gwyn, he also does a complete new bolt kit which is only £40 so you can guarantee that yours come out ok Rolling with laughter Rolling with laughter Rolling with laughter
Post #1058467 24th Jan 2025 4:30pm
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
Another vote here for Superpro,sourced from Gwyn Lewis. Thumbs Up
Post #1058473 24th Jan 2025 5:07pm
maranellohouse
Changed about 5 years ago. I'm not doing the work this time so I'll have those checked as well when it's with the guy doing the work. Thumbs Up 05 Alive tuned TD5 110 Defender
73 Fiat 500 F
92 Kawasaki ZZR 600
97 Ferrari 456GT
Post #1058481 24th Jan 2025 6:18pm
maranellohouse
with votes like those I know where I'll be going. Thanks guys. 05 Alive tuned TD5 110 Defender
73 Fiat 500 F
92 Kawasaki ZZR 600
97 Ferrari 456GT
Post #1058482 24th Jan 2025 6:18pm
Mr.Jimbo
United Kingdom 2003 Defender 110 Td5 CSW Java Black
Superpro all the way, plus a lot easier to fit DIY.
Personally on a TD5 era 110, I found I only needed new bolts on the upper A Arm bushes, the rest were OK to re-use, although the rear trailing arm on the axle were bloody tight. A day or two before you start, go round with a wire brush and some WD40/Plusgas and clean up the threads on all the bolts, will make it a lot easier.
Post #1058518 25th Jan 2025 12:49am
Les Brock
Superpro from Gwyn Thumbs Up Regards
Les
Def 90 M57
Post #1058522 25th Jan 2025 7:09am
4RF RDS
Went through this last year on my 2000 MY 110 CSW. It was a few things. Suggest you check, panhard rod bushings first and confirm condition of radius arm bushings. Then check steering column u-joints, and finally swivel ball bearing and preload and overall condition. Lastly check front tire balance.
It turned out to be panhard rod, radius arm and u-joints which all added up to horrible wobble.
I chose genuine rubber bushings for my replacements. They lasted 23 years the first time. 🤷‍♂️
Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #1058581 25th Jan 2025 6:33pm
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
Superpro - blue
I have had them on my 90 for over 10 yrs on the equator and they are still doing great.
recently the 90 has migrated to face her 3rd canadian winter and is still holding up nice.
Fit that once and pretty much forget about it.
when i changed out the trailing arm rubber bushes the last time, they pretty much became oval at the hole. the radius arm rubber bush has worn till i got a conical tyre. The defender has migrated, leaving the owner behind.
Post #1058639 26th Jan 2025 11:42am
maranellohouse
Excellent information everyone, thank you all for taking the time to post, I'll be having all of your suggestions looked at as I've had the Landy 11 years and of all the cars I have its the one car I'll have until I can no longer climb into it. Thumbs Up Thumbs Up Thumbs Up 05 Alive tuned TD5 110 Defender
73 Fiat 500 F
92 Kawasaki ZZR 600
97 Ferrari 456GT
Post #1058642 26th Jan 2025 12:24pm
