Home > Technical > Engine Knocking
SVRDefender90
United Kingdom 1990 Defender 90 V8 Petrol PU Auto Belize Green
Engine Knocking
I've just rebuilt a rover 3.9EFI V8 from scratch, it's in the defender and I'm turning the key for the first time but experiencing a deep heavy knocking when cranking.
During diagnosis I've unplugged injectors and fuel pump to be sure it's not hydro locking.
Compression test showed 160-175psi on all cylinders.
This isn't an oil pressure issue, all is well primed.
The engine was rotated by hand on the engine stand without issue.
The spark plugs have been checked incase they're impacting pistons but there's no contact.
If all spark plugs are removed (no compression), there is no knocking and it sounds perfect. The knock returns with just a single plug inserted into any cylinder and only on the compression stroke. Interestingly with 8 spark plugs inserted, it develops into a rhythmic triple knock, instead of a logical 8.
Any suggestions would be incredibly appreciated!
Post #1057576 16th Jan 2025 7:21pm
Big end?
Post #1057579 16th Jan 2025 8:14pm
SVRDefender90
Re: Engine Knocking
blackwolf wrote:
Big end?
I wondered that but you'd think it would only show on the big end that has the issue, but I can put a plug or even a compression tester in any hole and get the knock.
The whole engine had a complete set of brand new bearings after the rotating assembly was balanced.
It had some new pistons machined which I was suspicious of, but the knock is too heavy for a piston slap on cranking I'd imagine.
Post #1057580 16th Jan 2025 8:18pm
andy63
No idea about cause but I'm thinking if the sump was easily dropped that might be an idea to see if there are any signs of contactanywhere on the bottom end?
Post #1057629 17th Jan 2025 9:13am
LR90XS2011
loose flywheel? or damaged teeth on starter or flywheel? DEFENDER 90 TDCI XS,
Post #1057667 17th Jan 2025 3:51pm
