Home > Td5 > Help diagnosing engine cutting out issue
Page 2 of 2 <12
TD5Ad&Alf
England 2003 Defender 110 Td5 CSW Belize Green
More testing today, replaced the injector loom - no better - Removed CPS, very dirty and plug was also dirty (rear of rocker gasket was leaking straight onto the CPS) unfortunately I broke it getting it out so will have to replace it now. Embarassed
What I have noticed today is that the car only cuts out when the engine is revved fairly hard and if I switch the ignition off and wait after 1-2mins the main relay under the drivers seat clicks and the car can be restarted.
I’m thinking MadTom is right likely an ECU issue, I removed the ECU this evening and opened it, its extremely clean inside, I can’t see anything obvious but I guess I wouldn’t if a component had failed.
I’ll try the new CPS when it arrives and report back, but if anyone has a good ECU for sale please PM me!
Post #1057898 19th Jan 2025 7:41pm
MadTom
Main realy, that power the engine ECU is controlled byt the engine ECU - after ignition off, it takes cca. 10 second to power this relay off. This delay is controlled by the CPU in engine ECU. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1057949 20th Jan 2025 10:04am
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
Re: Help diagnosing engine cutting out issue
TD5Ad&Alf wrote:
the EML light comes on just as it cuts out, but this could be due to the engine dying as it goes out as normal when the car restarts.
Was it red and did it say on until the ignition turned off?
As far as I'm aware, only the crank position sensor or associated wiring will cause the engine to shut off with the red malfunction light immediately illuminating.
Broken sensor = Replace
Faulty wiring = https://www.empiretuning.co.uk/product/td5...y-harness/
Post #1058084 20th Jan 2025 11:27pm
TD5Ad&Alf
It’s the yellow EML which comes on when it stalls, no sign of the red crossed eml at all, i did notice that the glow plug light doesn’t illuminate when it’s cranking but not starting, if I wait until the main relay clicks the glow plug light does illuminate and it starts, but it might not be connected.
Post #1058174 21st Jan 2025 9:15pm
TD5Ad&Alf
I’m going to replace the CS at the weekend and the plug & section of the loom. If that doesn’t make any difference I’ll get the codes read and send the ECU off.
Does anyone know if a garage quality snap on code reader will read td5 fault codes? I’ve tried my cheap code reader and don’t get anything.
Post #1058175 21st Jan 2025 9:17pm
rustandoil
Just read this thread.... I had similar, replaced Crank sensor and all good..
Post #1058177 21st Jan 2025 9:25pm
TD5Ad&Alf
Really hope the CS solves it, the old one was very dirty both on the tip and around the connector/harness so maybe the issue?
I read a post about a very similar fault description which turned out to be the ECU
Was yours cutting out when revved? And restarting fine after a brief wait?
Post #1058182 21st Jan 2025 9:54pm
rustandoil
No, mine was crank no start, and briefly cutting out during normal running with the engine light just flashing on for a second or two but not putting me at the side of the road.
Before I swapped the crank sensor I also fitted a new fuel pump relay and main relay the socket of which is a little discoloured from getting hot....
Post #1058192 22nd Jan 2025 3:24am
TD5Ad&Alf
As an update the crank sensor replacement made no difference 🙄 I also checked the Westgate as I guess it’s possible for the ECU to shut the engine off if it detects an increased boost pressure? Anyway wastegate was free so it’s not that either. so next step is to get the ECU codes read. I’ve ordered an AlivePower flash reader as they were offering the 10AS adapter free (I only have one fob for the alarm so this will come in handy) it should arrive this week so I’ll have the codes at the weekend. If anyone is considering selling an NNN500020 ECU please PM me (be worth having a spare!)
Post #1059503 4th Feb 2025 1:33pm
rustandoil
I have to say the the Alive Power flash looks pretty good, should be easier to use than Nanocom MK1
I hope it helps you sort out what going on Thumbs Up
My cutting out issue has returned, Nanocom says "noisy crank signal was detected"..... I suspect (hope) that its because of a slave cylinder leak causing muck to be chucked around the bell housing....I will take the CPS out and give it a wash with brake cleaner.
Post #1059567 5th Feb 2025 9:41am
TD5Ad&Alf
Ok so update on this issue.
After reading the codes using the Alive Power Flash software the code which came back was “top side switch failed” The software showed the ECU shutting down at 2500RPM.
I took the ECU to ECU testing in Heanor, I have to say it’s an impressive place! They called me after 3days to say the fault was repaired. When I went to collect it I spoke to a very knowledgable guy who said the issue was the larger of the two capacitors (One is 40v other is 100v) he said that’s why it was shutting down at 2500rpm - apparently the first smaller capacitor controls above idle to 2500rpm when the larger one takes over. Anyway they have replaced both and now the ECU has a lifetime warranty.
Fitted it back in the car today - 25mile trip to test and no issues - I now have one happy son again!!
Thanks for the feedback on this post, very useful whilst fault finding!
I’d certainly recommend ECU Testing if anyone has a similar fault!!
Post #1061686 1st Mar 2025 5:57pm
MadTom
Just to make it a bit more clear, how the ECU works - injectors are not controled by capacitors any way. Capacitor for lower voltage is there to store enough power for all ECU, like your cars battery. Because 12V is not enough to drive solenoid in injector, there is a big powefull DC-DC converter inside of ECU, changing 12V to 85V. Capacitor for higher voltage is there to store enough power at 85V to controll injectors. Injectors are switched to ground by one common switch and to 85V by 5 seperate switches. These switches - TOP side and BOTTOM side are made by FET transistors controlled by ECU CPU. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1061776 2nd Mar 2025 9:58pm
Page 2 of 2 <12
