![]() | Home > Modifications & Maintenance (L663) > I6 Diesel MHEV, deactivate start-stop system, a good idea? |
Crazymind Member Since: 11 Jun 2024 Location: Glasgow Posts: 235 ![]() ![]() |
Depending on the situation it can be quite annoying and kind of frightening. Start Stop is a modern feature which has been proven reliable and it doesn't damage the engine. It saves fuel and the Planet
![]() For us coming from Carburettor engines...who dared to switch the engine off at the light? You never knew if the engine was going to start or not... However If I switch the button off in the defender the next time I get in the car it is always off till I press the button to activate. Simple as that. |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1212 ![]() ![]() ![]() |
I am not sure it saves the planet, but rather it allowed the manufacturer to give their model a few tax benefits on the designed test cycle .
ruben Member Since: 04 Feb 2021 Location: ASTURIAS Posts: 308 ![]() ![]() |
Ok, leaving the health of the planet out… isn't a stopped engine in the best possible condition? I mean it's safe from any incident dilution or wear, right? That's why I think that S/S is not a bad idea these days, right? And in this I6 you can't even hear it when it restarts, and you will save a lot of hours of use over time, and that can only be beneficial! so why disable it then? Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2719 ![]() ![]() |
There are some situations where it is appropriate, for example waiting at a traffic light, but also many where it is not - for example coming to a stop at a roundabout where you will need to pull away in a few seconds. I also find it annoying when moving trailers around or stopping to open and close gates.
By enabling the last user mode setting, it simply remembers my preference on each ignition cycle rather than defaulting to on. Therefore I can have it off for most of the time and then if I come to a situation where I want to let it stop the engine I can just press the button to do so. In practice I only do this in situations like the traffic light example above, where I am going to be stationary for several minutes and therefore it is worth stopping the engine. |
I don't find any inconveniences in roundabouts etc... I let it manage in all situations, since, at least in mine, the restart is so extremely fast, silent, refined and solvent that I even enjoy the situation when it kicks in. At first it was a bit difficult for me, it seemed strange to me because I had always used similar systems, but they were old ones managed with a classic starter motor and it was a definitely horrible experience, but now it is not like that, and we understand each other very well, I am delighted as with everything else of this magnificent car... now I never disconnect it under any circumstances. Defender 110 SE I6 D250 23MY
It’s not really the inconvenience in the roundabout situation, as you say it restarts very quickly and silently. It’s more that I don’t think it’s good for an engine to go from zero oil pressure and 0 rpm to high load instantly such as when pulling away quickly onto a roundabout/junction.
When stopping to open/close gates or hook up trailers it’s just annoying as if the start/stop kicks in when you stop it then shuts off the whole car when you open the door. Disabling it keeps the engine running. |
After a long motorway run coming to alt doesn’t seem ideal…
Well, I can agree with that!! 👍🏼…and I also don't like everything turning off when you open a door...it's true too, I don't like that very much.👍🏼👍🏼 Defender 110 SE I6 D250 23MY
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3015 ![]() ![]() |
l used the GAP tool to make the vehicle remember the stop/start setting. So if l turn it off, it stays off. But l can turn it on if l want to use it.
l never turn it on, l don't like it at all and l don't think it's good for the engine. Although l am sure others will disagree. |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1468 ![]() ![]() |
I never turned mine off. Never noticed it all
l have to say that on the 3.0 the stop/start is very smooth and you barely notice it.
The engine is very quiet. l've had customers ask if it's electric. |
Yes! Me too! Defender 110 SE I6 D250 23MY
