Home > General & Technical (L663) > Wireless Mobile Phone Dock for L663 Defender - AliExpress?
Andy3149
Good afternoon from a lurker!
I’m looking to get a wireless mobile phone dock. Searches show several UK sellers listed at £150 - 200 which appear to be exactly the same as the docks available on AliExpress for less than £100
https://www.aliexpress.com/item/1005007276417029.html
The images on one UK site show the back label written in Chinese with no UK manufacturer.
Has anyone bought one from AliExpress and has positive/ negative thoughts? I’m sure that they are exactly the same but wanted to see if anyone had experience.
Post #1056897 10th Jan 2025 2:26pm
ThunderBob
United States
Andy3149
I’ve been pretty successful on the few items I’ve bought through AliExpress. For the price I would consider them. If you’re not satisfied with the quality you have 90 days to return it. Good luck!
Post #1056910 10th Jan 2025 3:17pm
Andy3149
Thanks for the reply Bob - I’m sure they’ll be the same unit anyway! Will pull the AliExpress trigger
Post #1056958 10th Jan 2025 7:41pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
It will be exactly the same part as UK suppliers supply, I find it easier to buy from Alliexpress and cut out the middle man and save some money. It's perfectly safe buying from them, the seller doesn't get paid by Alliexpress until you are happy with the order. I've bought quite a bit from them, not all Defender parts, and have only had one or two problems but I've either got a refund straight away or worked with the seller to rectify it Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1056997 11th Jan 2025 12:55am
Crazymind
I have got a double option:
Post #1057023 11th Jan 2025 12:23pm
Andy3149
Many thanks for the above Ian
I hadn’t realised it worked like that, more that you just dealt with the seller directly over the platform. Does seem more reassuring. Have ordered.
Thanks again
Post #1057037 11th Jan 2025 3:16pm
Andy3149
Should have posted a picture, I’m interested in the dock which sits in the void at the front of the central console. At least your set up means that the screens are more visible than the dock. Cheers though
Post #1057038 11th Jan 2025 3:17pm
Crazymind
Here more photos:
It’s designed and produced by Powerful Uk. Not very well I have to say. Some adjustment is needed to fit the MagSafe.
It’s good enough to hold my iPhone 15pro and looks neat. Not cheap though. 30quid the support and 35 the MagSafe.
The charger at the top is from Aliexpress, 25quid including the dashboard support.
Both serve different scenarios.
Post #1057047 11th Jan 2025 4:25pm
