Home > General & Technical (L663) > Wireless Mobile Phone Dock for L663 Defender - AliExpress? |
Andy3149 Member Since: 08 Jan 2025 Location: Hampshire Posts: 4 |
Good afternoon from a lurker!
I’m looking to get a wireless mobile phone dock. Searches show several UK sellers listed at £150 - 200 which appear to be exactly the same as the docks available on AliExpress for less than £100 https://www.aliexpress.com/item/1005007276417029.html The images on one UK site show the back label written in Chinese with no UK manufacturer. Has anyone bought one from AliExpress and has positive/ negative thoughts? I’m sure that they are exactly the same but wanted to see if anyone had experience. Cheers |
10th Jan 2025 1:26pm |
Thanks for the reply Bob - I’m sure they’ll be the same unit anyway! Will pull the AliExpress trigger
10th Jan 2025 6:41pm |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1420 |
It will be exactly the same part as UK suppliers supply, I find it easier to buy from Alliexpress and cut out the middle man and save some money. It's perfectly safe buying from them, the seller doesn't get paid by Alliexpress until you are happy with the order. I've bought quite a bit from them, not all Defender parts, and have only had one or two problems but I've either got a refund straight away or worked with the seller to rectify it Cheers Ian
-------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
10th Jan 2025 11:55pm |
Crazymind Member Since: 11 Jun 2024 Location: Glasgow Posts: 176 |
I have got a double option:
Click image to enlarge |
11th Jan 2025 11:23am |
Many thanks for the above Ian I hadn’t realised it worked like that, more that you just dealt with the seller directly over the platform. Does seem more reassuring. Have ordered. Thanks again |
11th Jan 2025 2:16pm |
Should have posted a picture, I’m interested in the dock which sits in the void at the front of the central console. At least your set up means that the screens are more visible than the dock. Cheers though |
11th Jan 2025 2:17pm |
Here more photos:
Click image to enlarge Click image to enlarge It’s designed and produced by Powerful Uk. Not very well I have to say. Some adjustment is needed to fit the MagSafe. It’s good enough to hold my iPhone 15pro and looks neat. Not cheap though. 30quid the support and 35 the MagSafe. The charger at the top is from Aliexpress, 25quid including the dashboard support. Both serve different scenarios. |
11th Jan 2025 3:25pm |
