![]() | Home > Maintenance & Modifications > 110 footwell heater duct modification? |
willyj Member Since: 23 Oct 2009 Location: Carmarthenshire Posts: 197 ![]() ![]() ![]() |
Hi all,
Has anyone managed a successful modification to get heater air to blow out in middle row footwell? I was sure I came across something before but searched everywhere so must have dreamt it. TIA |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3818 ![]() ![]() |
Interested in this,
The lower duct near the bottom of gear stick doesn't half pump out heat once warm... I'm thinking a bit like my Series 1 some ducting and outlets each side of the arm rest could work? |
This idea but smaller diameter,
Then run each pipe either side of the cubby (or inside) so the vents face each passenger. Its how you secure the front end to retain the heat. https://www.amazon.co.uk/Heater-Outlet-Die...B0CBCD8HNC |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5920 ![]() ![]() ![]() |
Not sure if a TD5 has enough waft in the motor to push the warm air all the way into the rear, might need some inline fan to assist.
A Puma might be different. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
under neath centre console in the transmission tunnel I was thinking. Where to take the feed from is the question
