Home > Maintenance & Modifications > 110 footwell heater duct modification?
willyj
United Kingdom 2011 Defender 110 Puma 2.4 USW Stornoway Grey
Hi all,
Has anyone managed a successful modification to get heater air to blow out in middle row footwell?
I was sure I came across something before but searched everywhere so must have dreamt it.
TIA
Post #1056791 9th Jan 2025 3:42pm
excossack
I've pondered this for a while as well and short of cutting into the lower dash the only other way I thought of was to some how duct from the knee vents and come along the transmission tunnel.
Mine is a TD5. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1056796 9th Jan 2025 4:32pm
Stacey007
Interested in this,
The lower duct near the bottom of gear stick doesn't half pump out heat once warm...
I'm thinking a bit like my Series 1 some ducting and outlets each side of the arm rest could work?
Post #1056798 9th Jan 2025 4:33pm
Stacey007
This idea but smaller diameter,
Then run each pipe either side of the cubby (or inside) so the vents face each passenger.
Its how you secure the front end to retain the heat.
https://www.amazon.co.uk/Heater-Outlet-Die...B0CBCD8HNC
Post #1056799 9th Jan 2025 4:43pm
excossack
Not sure if a TD5 has enough waft in the motor to push the warm air all the way into the rear, might need some inline fan to assist.
A Puma might be different. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1056800 9th Jan 2025 4:44pm
willyj
under neath centre console in the transmission tunnel I was thinking. Where to take the feed from is the question
Post #1056811 9th Jan 2025 6:05pm
