Home > Puma (Tdci) > Second row door actuator photo
Will@LRW
 1997 Defender 110 300 Tdi CSW Alpine White
Just wondering if anyone has photos of the second row door central locking actuator, how it's fastened to the inner panel and what the linkage looks like?
Cheers! LR Workshop
New parts illustrations https://www.lrworkshop.com/diagrams/land-r...ed-corners
Find a Defender's history and spec: https://defender.lrworkshop.com
Post #1056167 2nd Jan 2025 11:00pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
Post #1056274 4th Jan 2025 5:00am
jonny
It doesn't show the fixings on there - it's two self tappers through the inner door skin to release it.
I need to change my actuators - undoing them is easy, but getting them off the linkage looks to be a pain as there's not enough room to unhook them easily.
Post #1056288 4th Jan 2025 12:02pm
Will@LRW
Thanks for the link, although the reason for having photos is that the diagrams are wholly unhelpful and I'm making an alternative. I've bought most of the pieces so far, but as Jonny says the screws aren't listed.
The linkage on the actuator is a double hooked. I've found you can't get it onto the 3-way bell crank without that being taken off the inner frame, which means removing the frame. Unhooking from the actuator may require the same process.
Jonny, would you be able to post a picture of the screws? From vague photos I've seen they look like they're flanged headed. LR Workshop
Post #1056299 4th Jan 2025 1:49pm
Will@LRW
Have seen some photos of Td5 era and looks to be similar to the dash screws, so tried these for size. The Puma ones might be Torx but no idea on a part number. Can anyone confirm?
Also tried this other dash screw but is probably too small
 LR Workshop
Post #1057171 12th Jan 2025 5:49pm
