Home > Puma (Tdci) > Second row door actuator photo |
Will@LRW Member Since: 04 May 2019 Location: UK Posts: 191 |
Just wondering if anyone has photos of the second row door central locking actuator, how it's fastened to the inner panel and what the linkage looks like?
Cheers! LR Workshop Find a Defender's history and spec: https://defender.lrworkshop.com |
2nd Jan 2025 10:00pm |
jbcollier Member Since: 29 Apr 2024 Location: Edmonton AB Posts: 129 |
This is the stock set-up.
https://parts.jaguarlandroverclassic.com/p...zNTUwOTgx/ |
4th Jan 2025 4:00am |
Thanks for the link, although the reason for having photos is that the diagrams are wholly unhelpful and I'm making an alternative. I've bought most of the pieces so far, but as Jonny says the screws aren't listed.
The linkage on the actuator is a double hooked. I've found you can't get it onto the 3-way bell crank without that being taken off the inner frame, which means removing the frame. Unhooking from the actuator may require the same process. Jonny, would you be able to post a picture of the screws? From vague photos I've seen they look like they're flanged headed. LR Workshop Find a Defender's history and spec: https://defender.lrworkshop.com |
4th Jan 2025 12:49pm |
Have seen some photos of Td5 era and looks to be similar to the dash screws, so tried these for size. The Puma ones might be Torx but no idea on a part number. Can anyone confirm?
Click image to enlarge Click image to enlarge Also tried this other dash screw but is probably too small Click image to enlarge LR Workshop Find a Defender's history and spec: https://defender.lrworkshop.com |
12th Jan 2025 4:49pm |
