Home > Maintenance & Modifications > How to tell a good turbo from a bad turbo?
excossack
I have a couple of spare turbos from a TD5 - How do you tell a good turbo from a bad/worn turbo?
One looks more sooty than the other and both impellers feel the same. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1056093 2nd Jan 2025 11:41am
MK
"little" radial movement and no axial movement on the shaft. My 2pc Puma 110" SW
Post #1056097 2nd Jan 2025 12:23pm
excossack
Cheers. I did spin the impeller and no real play that I could feel.
Might be a case of fit it and see what its like 1999 Defender TD5 110
Regards
John M0VAZ
Post #1056098 2nd Jan 2025 12:33pm
MK
You could also disassemble it and check both ends, waste gate actuator and vanes. For this you will need some seal kit. Puma 110" SW
Post #1056099 2nd Jan 2025 12:46pm
Dinnu
^^this.
Visual inspection perhaps especially look at compressor side that it had no contact with the scroll. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1056138 2nd Jan 2025 6:22pm
You can check the vanes are free as well. TheThunderRolls🇬🇧🇺🇸
Post #1056140 2nd Jan 2025 6:29pm
julian
United Kingdom 1994 Defender 110 300 Tdi CSW Alpine White
In my experience the vanes on the impeller side get jagged.
I can't understand why as it's all post filter, but, irrespective, that's my findings.
I don't know td5 units as all mine are 300s, but check the waste gate actuator too. If that's all seized up you won't want to use that one.
If you've got an air compressor just blowing air into the actuator input should move it. I don't meen coupling it properly - just with a blow gun and a leaky union
When you fit the unit spend some time with a little syringe or something loading it with oil. Noone ever seems to get the replacement cartridges to work and I do wonder if inadequately priming is the problem.
As in load it up and leave it over night or whatever, and then go again.
Post #1056141 2nd Jan 2025 6:30pm
My motto is just keep a clean air filter, what goes in, goes through.
Lots of people run, and run, the air filter till it’s clogged up badly, and invariably by that stage it loses its filtration efficiency, the bad stuff can then get by, minimally, but still happens bit to mention the restriction and recused performance and economy.
Not specific to LR’s but all vehicles, really LR’s are good, at least in U.K. environment as the air inlet is relatively high and clean with a good size air box and filter.
Quite a few cars out the have the air inlet about 14” off the ground. Whistle
Not just for picking up dust and dirt, but good at picking up water laden spray and flooding too.
And that doesn’t end well when the driver thinks they have a boat and “it doesn’t seem to want to go no more”.
Shocked Laughing TheThunderRolls🇬🇧🇺🇸
Post #1056142 2nd Jan 2025 6:36pm
Not on a TD5, it's a fixed vane, wastegate type turbo unlike the Puma.
Post #1056152 2nd Jan 2025 8:38pm
Ah I see, my mistake I know very little about the TD5. Wasn’t posted in the TD5 section so presumed it was Puma. Thumbs Up TheThunderRolls🇬🇧🇺🇸
Post #1056153 2nd Jan 2025 8:44pm
excossack
I did mention td5 in the first post..... Smile
The impeller you can see spins ok with no damage to the vanes and does not catch the housing. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1056191 3rd Jan 2025 12:01pm
julian
If they both look and feel the same, check the waste gate / actuator and then just fit one of them.
Just because you have two of them, doesn't mean to say one is better than the other - they may both be absolutely fine! : )
Post #1056194 3rd Jan 2025 12:05pm
camelman
IT's only a 20 minute job to swap them so I'd give it a go.
There is a risk is of snapping the studs if theyre not new however...
Post #1056201 3rd Jan 2025 1:33pm
excossack
That was my thought - swap and see. Might need new gaskets first.
The bolts for the exhaust down pipe and manifold bolts have not been removed for many years.
The waste gate on one of them is adjusted differently to the other. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1056202 3rd Jan 2025 1:38pm
MK
IIRC you need around [20] psi to make the actuator move the rod/spindle Question all its way. Puma 110" SW
Post #1056208 3rd Jan 2025 3:21pm
