Home > Puma (Tdci) > Another non starter
Siwynne
Another non starter
Following a 240 mile round trip I parked up and unloaded on the drive at home. On returning to move the truck the fob didn’t work and the immobiliser remained on.
The green 10as I had fitted by a local Indy after the same experience four years ago had failed.
I have purchased another green 10as and a Nanocom. The fob is now working but being new to the Nanocom I am struggling to get the immobiliser to disarm. Any suggestions appreciated
Post #1055389 23rd Dec 2024 8:47am
Siwynne
2.2 by the way
Post #1055391 23rd Dec 2024 8:53am
cretesimon
Greece
Or get the immobiliser removed for the car
Post #1055539 24th Dec 2024 12:18pm
Ianh
Post #1055546 24th Dec 2024 1:10pm
Siwynne
I have now found a step by step walk through of installing a green 10as on a puma on the Nanocom forums so will give it a go when the Christmas dust settles
Post #1055561 24th Dec 2024 2:52pm
Siwynne
Ianh wrote:
Any help ?
For 10AS
https://www.nanocom-diagnostics.com/upload...0Guide.pdf
For later ALM (CH serial no’s)
https://www.nanocom-diagnostics.com/downloads/preview/alm-ecu
I have these thank you. I will go at it slowly next week and get sorted
Post #1055562 24th Dec 2024 2:53pm
Ianh
A key thing is to resync the 10AS to the engine ECU, which the Nanocom can now do.
Post #1055566 24th Dec 2024 3:39pm
Siwynne
Yes
I spent a good few hours researching how to do this with the Nanocom last night. I’ll get to it after the festivities
Post #1055581 24th Dec 2024 5:07pm
Siwynne
The Nanocom has a function in ecu to “resynch ecu” when this is pressed the option to synch immobiliser appears and it does this immediately. No flashes or beeps.
Truck started first try after this
Post #1055742 27th Dec 2024 6:51pm
Ianh
As I thought, a 10AS to engine ECU resync would be key.
What is worrying is that your 10AS randomly lost sync to the Engine ECU. This is not normal behaviour. I wonder if power to the 10AS was lost at some point. So worth double checking connectors and fuses are seated well.
Post #1055743 27th Dec 2024 7:04pm
Siwynne
All connections and fuses were cleaned and checked before purchasing another unit. The expired unit is from 1996 and the “new “ one is from 1995. I will split the old one and examine it for dry joints and may even have it repaired for future use. The nearly 30 years of age of the expired unit could be part of the issue and one I could be dealing with the next one
Post #1055745 27th Dec 2024 7:13pm
Ianh
Post #1055749 27th Dec 2024 8:25pm
