Home > Modifications & Maintenance (L663) > Land Rover Defender Recalled for Snorkel That Could Fly Off
Naks
https://ca.finance.yahoo.com/news/land-rov...00796.html
"A small number of Land Rover Defenders are now subject to a peculiar recall related to the vehicle's adventure-ready snorkel, according to documents filed with the National Highway Traffic Safety Administration.
The recall, which was filed on December 6, is for a part number associated with 435 Defender units in the U.S. Internally known as VPLEP0543, the part number is for a raised intake that can be optioned onto the Defender 90 and 110 models. Instead of a traditional, engine-bay mounted intake, the raised intake funnels air through the A-pillar, allowing serious adventurers to plow into deeper water than they would otherwise be able to go.
However, Jaguar Land Rover is officially cautioning against wading too deep, due to a dimensional tolerance mismatch, NHTSA says. Officially, the federal safety agency says that the intake can separate from the A-pillar as a result of mismatched fitting tolerances, with the possibility of a complete departure of the intake — a.k.a. snorkel flies off — increasing at high speeds. ..."
https://static.nhtsa.gov/odi/rcl/2024/RCLRPT-24E102-3460.PDF --
Post #1054542 13th Dec 2024 8:02am
markb110
Well I guess that Land Rover had to go skipping off into the sunset holding hands with their besties Jaguar at some point in the nearest future……. Whistle
Post #1054583 13th Dec 2024 11:40am
LR Nuts
What of the Octa, will they fall off together or one at a time, at the speed they are likely to go.
Laughing
Post #1054590 13th Dec 2024 1:35pm
snowtiger
Germany
The snorkel is not for more wading depth. It is just a higher air intake for cleaner air, when driving in really dusty terrain.
Post #1054616 13th Dec 2024 6:21pm
lightning
lndeed. With a standard wading depth of a metre, l am not sure going any deeper than that would be wise, snorkel or no snorkel
Post #1054626 13th Dec 2024 8:28pm
LR Nuts
The true definition of the item is Raised Air Intake, not snorkel.
https://accessories-instructions.landrover...r/G4141782
Post #1054643 14th Dec 2024 6:54am
J77
I’m sure I read somewhere that’s why it’s 900mm, much more and there’s a chance it will float. 24MY 90 D250 HSE, Tasman Blue
Post #1054659 14th Dec 2024 11:17am
