![]() | Home > Modifications & Maintenance (L663) > Land Rover Defender Recalled for Snorkel That Could Fly Off |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2669 ![]() ![]() ![]() |
https://ca.finance.yahoo.com/news/land-rov...00796.html
"A small number of Land Rover Defenders are now subject to a peculiar recall related to the vehicle's adventure-ready snorkel, according to documents filed with the National Highway Traffic Safety Administration. The recall, which was filed on December 6, is for a part number associated with 435 Defender units in the U.S. Internally known as VPLEP0543, the part number is for a raised intake that can be optioned onto the Defender 90 and 110 models. Instead of a traditional, engine-bay mounted intake, the raised intake funnels air through the A-pillar, allowing serious adventurers to plow into deeper water than they would otherwise be able to go. However, Jaguar Land Rover is officially cautioning against wading too deep, due to a dimensional tolerance mismatch, NHTSA says. Officially, the federal safety agency says that the intake can separate from the A-pillar as a result of mismatched fitting tolerances, with the possibility of a complete departure of the intake — a.k.a. snorkel flies off — increasing at high speeds. ..." https://static.nhtsa.gov/odi/rcl/2024/RCLRPT-24E102-3460.PDF -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1261 ![]() ![]() |
![]() What of the Octa, will they fall off together or one at a time, at the speed they are likely to go. ![]() |
snowtiger Member Since: 06 Oct 2022 Location: Bavaria Posts: 33 ![]() ![]() |
The snorkel is not for more wading depth. It is just a higher air intake for cleaner air, when driving in really dusty terrain.
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3020 ![]() ![]() |
lndeed. With a standard wading depth of a metre, l am not sure going any deeper than that would be wise, snorkel or no snorkel
The true definition of the item is Raised Air Intake, not snorkel.
https://accessories-instructions.landrover...r/G4141782 |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3453 ![]() ![]() |
I’m sure I read somewhere that’s why it’s 900mm, much more and there’s a chance it will float. 24MY 90 D250 HSE, Tasman Blue
