- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Technical > Is it possible to trickle charge into a dual battery system? |
Bluest
gumdrop wrote:I was once told that with a Durite 140 amp VSR split charge relay all you need to do is put a switch on the neg feed to the VSR and this then stops (when the neg feed is set to off) the relay clicking in and therefore only charges the starter battery .. never tried it but it makes sense .. thoughts ?
That's right, it ie what I do. It works with all those generic VSRs like the Durite one. I use a plug to disconnect the earth rather than a switch though. I need to get round to swapping it to a switch really 2007 110 TDCi Station Wagon XS
14th Dec 2024 10:16am |
