![]() | Home > Modifications & Maintenance (L663) > retro fit heated steering wheel |
L7APK Member Since: 02 Dec 2024 Location: Lancashire Posts: 5 ![]() ![]() |
![]() Click image to enlarge Bring it on....Freezing ![]() |
Darrant1234 Member Since: 03 Nov 2024 Location: Wakefield Posts: 24 ![]() ![]() |
I'm interested in this too. Only models within budget that had heated steering wheels were wrong colour for me or was missing something else such as digital display.
I know there's a few companies offering it at like £1800 ish but surely it can be done cheaper. Like yourself i just want a standard wheel. |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3818 ![]() ![]() |
Speaking out loud as no idea if this is possible,
Can you buy a steering wheel from the breakers, with heated element, swap the air bag refit and have it coded to work? Chances are the wiring etc is already in place? No idea if this is correct but worth a google? edit to see this is available for £500... https://www.ebay.co.uk/itm/335711382851?_s...R8TWm-byZA |
its a little more involved than just the wheel, you also need the wiring loom and clock spring (think that's the right term) bit with the indicators and lights etc
https://huntersprestige.com/products/heate...s9CJA-6Dhn |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3011 ![]() ![]() |
lt says "from £1,150 depending on the type of wheel"
Chances are the wiring etc is already in place? Not a chance. Wiring harnesses are vehicle specific now. l wanted to fit the subwoofer in my Commercial but the wiring is not there. Last edited by lightning on 5th Dec 2024 1:53pm. Edited 1 time in total |
Ive emailed they will do one with a standard wheel for £1500 currently
Ritson Member Since: 11 Apr 2021 Location: France Posts: 192 ![]() ![]() |
£1,500 buys an awful lot of pairs of gloves, just saying!
I wanted to spec heated steering wheel with mine but didn't as it was only available with cold weather package which had the heated windscreen included which I couldn't abide because of the heating filaments which I found distracting when driving. Current: MY22 P400e SE Prior: Discovery Sport HSE, Jaguar F-Type S, Discovery 3, RR Vogue |
not sure what's changed then as mine has heated front screen and no heated steering wheel.
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1438 ![]() ![]() ![]() |
Different parts of the world have different specs. If it has a standard steering wheel you will need the heated wheel, the harness and the clockspring, Hunters Prestige are capable of doing it and are a great company to deal with ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
F-Typical Member Since: 05 Sep 2024 Location: Hereford Posts: 51 ![]() ![]() |
This will be the first car I've ever owned with a heated wheel - although I have driven hire cars with one. They are okay, but the use case in which they would provide benefit seems quite marginal - unless you suffer from Raynaud's Syndrome and the car is parked outside over night in cold weather. For the rest: are you going to dash from the house with no coat/gloves/scarf/hat and try to drive off immediately - no. So you get into the car and start it up, then let it warm up inside before removing coat/scarf/gloves/hat and setting off. Even then, that's probably only for longer trips. For short trips you're going to be leaving all the cold weather gear on for when you have to get out at the other end... ![]() The heated screen: the filaments vary in thickness and spacing between makes, and appear to be much less visible than the one I had in an F-Type coupe 10 years ago. Maybe look at a few other marques that offer them to check if something less distracting is now available. HTH |
