Home > Modifications & Maintenance (L663) > retro fit heated steering wheel
L7APK
The mistake I made buying the car I did , was to not buying one with a heated steering wheel, I realised this morning. Ive had one on every car ive owned for the last 20 years and forgot what a difference they make. I once did a retro fit on a 2007 discovery I owned and now need to do the same on my defender.
question is for those who know is ,which company does the best deal, or is it best buying everything from JLR and then getting it switched on....I just want the basic black leather, don't need carbon or any other fancy stuff.
Post #1053832 4th Dec 2024 8:27pm
L7APK
Bring it on....Freezing Big Cry
Post #1053834 4th Dec 2024 8:42pm
Darrant1234
I'm interested in this too. Only models within budget that had heated steering wheels were wrong colour for me or was missing something else such as digital display.
I know there's a few companies offering it at like £1800 ish but surely it can be done cheaper.
Like yourself i just want a standard wheel.
Post #1053883 5th Dec 2024 11:29am
Stacey007
Speaking out loud as no idea if this is possible,
Can you buy a steering wheel from the breakers, with heated element, swap the air bag refit and have it coded to work?
Chances are the wiring etc is already in place?
No idea if this is correct but worth a google?
edit to see this is available for £500...
https://www.ebay.co.uk/itm/335711382851?_s...R8TWm-byZA
Post #1053886 5th Dec 2024 11:33am
Darrant1234
its a little more involved than just the wheel, you also need the wiring loom and clock spring (think that's the right term) bit with the indicators and lights etc
https://huntersprestige.com/products/heate...s9CJA-6Dhn
Post #1053891 5th Dec 2024 11:45am
lightning
lt says "from £1,150 depending on the type of wheel"
Not a chance. Wiring harnesses are vehicle specific now. l wanted to fit the subwoofer in my Commercial but the wiring is not there.
Post #1053900 5th Dec 2024 1:50pm
Darrant1234
Ive emailed they will do one with a standard wheel for £1500 currently
Post #1053901 5th Dec 2024 1:53pm
Ritson
France
£1,500 buys an awful lot of pairs of gloves, just saying!
I wanted to spec heated steering wheel with mine but didn't as it was only available with cold weather package which had the heated windscreen included which I couldn't abide because of the heating filaments which I found distracting when driving. Current: MY22 P400e SE
Prior: Discovery Sport HSE, Jaguar F-Type S, Discovery 3, RR Vogue
Post #1053910 5th Dec 2024 2:45pm
Darrant1234
not sure what's changed then as mine has heated front screen and no heated steering wheel.
Post #1053911 5th Dec 2024 2:47pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
Different parts of the world have different specs.
If it has a standard steering wheel you will need the heated wheel, the harness and the clockspring, Hunters Prestige are capable of doing it and are a great company to deal with Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1053956 6th Dec 2024 12:12am
F-Typical
This will be the first car I've ever owned with a heated wheel - although I have driven hire cars with one.
They are okay, but the use case in which they would provide benefit seems quite marginal - unless you suffer from Raynaud's Syndrome and the car is parked outside over night in cold weather.
For the rest: are you going to dash from the house with no coat/gloves/scarf/hat and try to drive off immediately - no. So you get into the car and start it up, then let it warm up inside before removing coat/scarf/gloves/hat and setting off. Even then, that's probably only for longer trips. For short trips you're going to be leaving all the cold weather gear on for when you have to get out at the other end... Smile
The heated screen: the filaments vary in thickness and spacing between makes, and appear to be much less visible than the one I had in an F-Type coupe 10 years ago. Maybe look at a few other marques that offer them to check if something less distracting is now available.
HTH
Post #1053980 6th Dec 2024 11:02am
