![]() | Home > Technical > M57 Swap questions |
tommobot Member Since: 15 May 2018 Location: Stratford Upon Avon Posts: 32 ![]() ![]() |
X53, X5 with the 218bhp is the scenario I went for, which appears to be one of the more recomended setups from what I can gather. The engine loom is far longer than the 3 / 5 series variants.
The 218bhp will likely have an older 6hp26, but can easily be modernised with a 8HP. I think the electronic 6HP28 can be fitted aswell, but personally I'd either go miles away or keep the game (gearbox) If your DIY, house of torque website provides many usefull guides, info and basically all the supplies to attack the swap. Mine should be 270 / 280bhp with 600nm and the 8HP and I friggin love it! Theres a couple of builds on here, but the facebook groups are amazing source of info. I've not come accross a comprehenisve guide as so to speak, but its fairly self explanatory once you get stuck in, and the H.O.T give many brillaint guides on their website. Side note; I retrofitted M57 to a old 84' 110. Getting the engine swap to work with a modern Puma era defender will likely be more tricky! |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8220 ![]() ![]() ![]() |
There are quite a few on here that have done swaps with various versions into varying ages of defender. Did you try s search on it? Cheers
Welkman Member Since: 02 Nov 2014 Location: Essex colchester Posts: 333 ![]() ![]() |
Hi I will certainly have a closer look. I was wondering if there were any current members that had completed the swap, so I could pick their brains. Lots of useful info in the first post already. Thanks. I will try to remember to post a build log as well.
i have a 90 was 200tdi to 184/MT82 and a 130 was 2.4 to a 231/6hp28. threads are on here. Cheers
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 872 ![]() ![]() |
Not wanting to dissuade you, the M57 is a fine engine and popular swap, although I'd guess you are looking at circa £5k+ to buy all the bits and get it up and running. The 2.2 lump might not be the greatest in the world, but a proper map and bigger intercooler don't half make a difference and in many ways are more than enough for a Defender. And substantially cheaper than an M57 swap. My Uncles 65 plate 90 makes 190hp on the dyno, but the torque from low down is lovely, 5th gear will pull from something like 25-30mph all the way up to illegal motorway speeds with a really nice shove in the back. An M57 might be quicker if lined up for a drag race, but real world day to day I'd say the difference isn't as much as you'd think. If wanting to spend a chuck of money on an engine conversion, I'd probably be looking at a Jaguar V8 swap over an M57. |
