Home > Puma (Tdci) > LOCKED OUT AGAIN !!!!!!!!!
bunnyman
England 2009 Defender 90 Puma 2.4 HT Galway Green
Hi all , my defender 90 2.4 (09) has locked me out for the second time with keys on the front seat does anyone know why it has done this again ?
Post #1052779 24th Nov 2024 4:29pm
Screbble
Oh dear. Hope you get it sorted.
Post #1052782 24th Nov 2024 4:35pm
bunnyman
yes sorted now with the spare key but could do with finding out what's causing it
Post #1052783 24th Nov 2024 4:40pm
ickle
Auto relock if drivers door isn't opened or if the interior light switch is faulty the alarm/locking will think the door hasn't been opened...
HTH Keith
Post #1052788 24th Nov 2024 5:40pm
There is no auto-relock on a Puma (thank goodness).
The usual reason for a Puma (or TD5) to spontaneously relock is due to the driver's door lock mechanism being stiff, either through freezing or through gunge, and not fully unlocking. The "lock" switch on the mechanism can then tell the 10AS to relock the vehicle. The answer usually is to lubricate the lock mechanisms.
Incidentally it is never a good idea to open a Puma or TD5, put your keys on the seat or anywhere in the vehicle including the ignition, and then close the door especially in cold weather, for precisely the reasons you have found. My Puma has never done this spontaneous locking malarky but on cold days when de-icing I start the engine and either leave a door open or leave a window open far enough to reach in for the lock button, just to be on the safe side.
Post #1052791 24th Nov 2024 5:56pm
bunnyman
Thank you for that , the time before i let the dog out the back closed the door Keys on seat as I walked away there was two horn beeps then locked all doors
Post #1052793 24th Nov 2024 6:05pm
ickle
There is on mine........
Post #1052797 24th Nov 2024 6:25pm
bunnyman
What year is yours
Post #1052798 24th Nov 2024 6:27pm
landy andy
As blackwolf says. The drivers door doofa gets lazy and locks all the doors. Worse when cold. A new CL actuator and all good.
Post #1052800 24th Nov 2024 6:32pm
ickle
Mines late 2007 and will re lock if the drivers door isn't opened. when we return to the car with the supermarket trolley, I remotely unlock the doors, swmbo opens the drivers door whilst I open the back door and start loading the shopping, has always done it and is regardless of temperature.
As its getting older and more temperamental it does sometimes do funny things, but I believe that the 10As can be programmed to relock or not if required.
Keith
Post #1052802 24th Nov 2024 6:41pm
I've just checked and auto-relock is a configurable option on the 10AS : " Plip relock: When set to ENABLED the alarm will relock the CDL after a short time if the ignition has not been turned on after it was unlocked using the plip."
The unusual aspect of this, assuming that the above (from Black Box Solution's user data) is correct, is that it will auto-relock even if you have opened a door (most vehicles in my experience only auto-relock if no doors have been opened). This is problematical, and I would suggest could be the OP's problem.
Any competent diagnostic tool, such as Nanocom, should be able to change this setting. Ickle, I suspect that someone has changed your settings after the vehicle left the factory.
Post #1052817 24th Nov 2024 8:09pm
Waka56
Germany
Mine did that with the engine running when I was in front of a nice line of people waiting for me to move.. It has never done it again, but I must say that most of the time the key now stays in my pocket whenever I get out Rolling with laughter Making my Defender great again. (Or trying to at least xD)
Post #1052890 25th Nov 2024 2:48pm
landy andy
Yep. That was the same with me. Line of us leaving a nice green lane. Jumped out to chat to someone, and then it locked its self. Engine running, and my phone on the dash holder.
Since then, keys in pocket, or window open a bit. Thumbs Up Thumbs Up
Again never did it since
Post #1052897 25th Nov 2024 3:28pm
revd
no c/l on mine but I do keep a spare door key in my wallet - just a flat job from Timpsons, not the factory issue full fat version
Post #1052903 25th Nov 2024 4:00pm
It won't do it again until the day you forget to open the window or have the key in your pocket. The Defender will know, and will strike the instant the opportunity arises! Rolling with laughter
Someone I used to work with had a Rover 214 (or similar) which had the same tendency. He stopped on the double-yellows outside the bank to use the cash machine, and the car immediately locked him out. Engine running, keys and phone in the car. Busy road, double yellows. He wasn't a happy person but we all thought it was hilarious!
Post #1052911 25th Nov 2024 4:37pm
