Home > Faults & Fixes (L663) > Problems with the heated steering wheel
Hazelhunter
Germany
Hello guys, I drive a P400 Defender, built in 2020. The steering wheel heating recently stopped working. The switch on the steering wheel can be switched on and off normally and lights up, but the steering wheel no longer warms up properly. Big Cry
I'm afraid there's a problem with the heating wires...
Do you perhaps have an idea?
Greetings, Hazelhunter
Post #1052411 21st Nov 2024 12:44pm
A1C6
Australia
I'm pretty sure some other people have had an issue like this, and their heater for the wheel had just worn out and failed. Do your heated seats work?
Post #1052512 22nd Nov 2024 11:51am
lightning
l've heard of a few heated steering wheels failing. ln fact there was one at my local LR specialist when l was there last week, that they were trying to diagnose.
They said steering wheel is £2,400. l hope this is not correct. Although it's not the end of the world if it doesn't heat up, never had a heated steering wheel on my old Defender (or any previous car l've owned)
Post #1052545 22nd Nov 2024 5:46pm
Hazelhunter
Germany
yes, my heated seats work without any problems ...
Post #1052847 25th Nov 2024 7:01am
Hazelhunter
Germany
Oh dear, that would be really bad news. A professional can definitely get this done cheaper, I hope.
Thank you for your message !
Post #1052848 25th Nov 2024 7:04am
Gareth
I noticed my heated steering wheel seems to have started failing. It only heats the rear section of the wheel where your fingers are. The section facing the driver where your palms are is cold.
£2400! Hell that’s a lot! 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy
Post #1052850 25th Nov 2024 7:45am
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
£2400 for a steering wheel is Censored , the Alcantara V8 wheel, which is heated is 'only' around £740 Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1053063 26th Nov 2024 10:54pm
