Home > Faults & Fixes (L663) > Problems with the heated steering wheel |
A1C6 Member Since: 15 Oct 2024 Location: Australia Posts: 56 |
I'm pretty sure some other people have had an issue like this, and their heater for the wheel had just worn out and failed. Do your heated seats work?
22nd Nov 2024 11:51am |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2893 |
l've heard of a few heated steering wheels failing. ln fact there was one at my local LR specialist when l was there last week, that they were trying to diagnose.
They said steering wheel is £2,400. l hope this is not correct. Although it's not the end of the world if it doesn't heat up, never had a heated steering wheel on my old Defender (or any previous car l've owned) |
22nd Nov 2024 5:46pm |
Hazelhunter Member Since: 18 Nov 2020 Location: Hohenlohe Posts: 19 |
yes, my heated seats work without any problems ... |
25th Nov 2024 7:01am |
Oh dear, that would be really bad news. A professional can definitely get this done cheaper, I hope. Thank you for your message ! |
25th Nov 2024 7:04am |
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1115 |
I noticed my heated steering wheel seems to have started failing. It only heats the rear section of the wheel where your fingers are. The section facing the driver where your palms are is cold.
£2400! Hell that’s a lot! 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
25th Nov 2024 7:45am |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1421 |
£2400 for a steering wheel is , the Alcantara V8 wheel, which is heated is 'only' around £740 Cheers Ian
-------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
26th Nov 2024 10:54pm |
