Home > In Car Electronics (L663) > Carplay and media help!
lightning
My phone wants to connect to the Defender using both wifi and Bluetooth
Which should l use. l currently have a problem with playing Spotify from the phone, it keeps disconnecting and l have to press play to get it to start again.
On Bluetooth it keeps flicking between "connected" and "not connected" although still seems to work.
Should l use wifi instead?
Post #1052176 19th Nov 2024 12:23pm
Down & Dirty
I only connect with wifi, no issues with CarPlay and things like Spotify Thumbs Up My 24 HSE X-Dynamic 90 Carpathian Grey
Post #1052228 19th Nov 2024 7:04pm
lightning
l've reset the Pivi and left both wi-fi and bluetooth on. It seems to be working okay now.
The car has Spotify as an app, at one stage it would sometimes connect to that instead of the one on my phone.
Post #1052273 20th Nov 2024 9:10am
CincyRovers1
United States
I always use the USB-C port to play music, as it has the best sound quality and my phone gets charged. Plus, you won't have any connection issues unless your cable or USB port is broken.
I'm in the minority, but I hate Apple CarPlay. I deactivated it in the smart device settings so it won't connect every time I plug in my phone. It has its benefits for sure, especially in vehicles that have a basic infotainment system, but the last thing I want is iOS on my dashboard. 𝟐𝟎𝟐𝟏 𝐃𝐞𝐟𝐞𝐧𝐝𝐞𝐫 𝟏𝟏𝟎 𝐒 𝐏𝟑𝟎𝟎 (Pangea Green over Acorn/Lunar)
𝟐𝟎𝟐𝟑 𝐏𝐨𝐫𝐬𝐜𝐡𝐞 𝐌𝐚𝐜𝐚𝐧 𝐒 (Dolomite Silver over Black/Bordeaux Red)
𝟐𝟎𝟏𝟕 𝐃𝐢𝐬𝐜𝐨𝐯𝐞𝐫𝐲 𝐇𝐒𝐄 𝐋𝐮𝐱𝐮𝐫𝐲 𝐒𝐢𝟔 (Aintree Green over Vintage Tan/Ebony) - Gone
𝟐𝟎𝟏𝟏 𝐋𝐑𝟒 𝐇𝐒𝐄 𝟓.𝟎 (Ipanema Sand over Almond/Arabica) - Gone
Post #1052439 21st Nov 2024 5:51pm
A1C6
Australia
Re: Carplay and media help!
Connectivity in these cars is really difficult. I tend to use a cable over Bluetooth since it can charge my phone and be connected reliably at the same time.
Post #1052473 22nd Nov 2024 5:52am
haymeister
Japan
No issues for me .
Mine connects fine wirelessly or wired with Apple Carplay.
And if wired and I unplug the phone then it switches automatically to wireless (the maps need a few seconds to catch up if mid-navigation)
I am also signed in with Spotify so can listen to that through the Pivi system. 22MY Defender 110 D300 S in Pangea Green and Contrast White Roof
IG defender_japan "Hulk san"
Post #1052484 22nd Nov 2024 9:21am
Moo
Ukraine
No issues. No idea if I'm connected via Bluetooth or Wifi. Also use the cable. Seamless connection always. Thumbs Up Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1052486 22nd Nov 2024 9:51am
ruben
Spain
I don't have any problems with this neither, but in these cases I always blame the weakest part, in this case it is the phone, its OS or its damn updates... I would delete the device from the car and reinstall it... it connects via BT,or let it manage itself and forget it, it works, nothing happens to the car!! Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE
Post #1052497 22nd Nov 2024 11:11am
lightning
UPDATE
Now sorted, the issue was my phone was installed on two separate accounts so the system didn't always connect to the same one.
l disabled one of the accounts and all is fine now (one was set to "default" and the other was set to "always connect" so no wonder l had issues)
Post #1058012 20th Jan 2025 7:08pm
