![]() | Home > Tdi > Dead N/S dipped beam headlight. 1991/200 |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5848 ![]() ![]() |
Have you physically removed the fuses? Or tested you are getting same reading both sides of the fuse.
Should be fuse 12. 7.5amp. Blue with pink trace. Wire colour |
Mining Subsidence Stu Member Since: 06 Mar 2024 Location: Cornwall Posts: 32 ![]() ![]() ![]() |
Pulled all 4 of them. All fine, all seated fine, no dodgy looking wires.
It is only the left and main beam works so it's not an earth problem. the truck had a new loom in 2016 and it's all like new. I am thinking it has to be either a switch or relay. But which one where! I presume the stalk controls are both dipped/ both main. If I'm right then it has to be where it splits between the both sides/individual sides. Relay? Time to take the haynes manual for a dump. |
white110 Member Since: 09 Dec 2017 Location: wales Posts: 10 ![]() ![]() ![]() |
Wiring loom where it passes behind the heater, that is where mine chaffed the insulation, plastic had gone brittle.
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5259 ![]() ![]() |
my old TDi had this trouble, and i would lose the dash lights at the same time too. For some reason it stopped doing it, when i changed the head light bulbs, when i changed the lights to crystals. I suspected that the switch it self had something to do with it, with them not been relayed. i never got the chance to find the issue out. But for the record, i swopped the bulbs to Philp's bulbs which stopped the problem. So it might be worth swopping the bulbs for good quality units, just to see if that helps, then buy the boomslang loom with a new switch. ![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
