Home > Puma (Tdci) > Heating stopped and slider loose...
RoseyLRO
Hi,
New to the forum..Hi!
Used many of the how-tos in the past and recently to replace the wiper park switch.
Long time 90 owner, but a new puma 2.4 owner. Heating has worked fine, sliders a little stiff, but the other day the heater fan slider went loose and there is no 'blow' Big Cry
Im guessing maybe a cable has gone? Ive had a look at some of the threads on here and am thinking my first move is to remove the console and have a look behind?
Struggling to find photos/instructions of whats normal and what to look out for, also read about cables under the bonnet?
Any pointers gratefully received as currently sat with hot waterbottle buddy commuting!
Post #1051396 12th Nov 2024 8:49am
Cragster69
Scotland 2007 Defender 110 Puma 2.4 CSW Cairns Blue
This thread has some information and pictures that could be helpful
https://www.defender2.net/forum/topic78660.html?highlight=valve Craig.
“Don't believe everything you read on the internet.” ― Abraham Lincoln
www.scotgrc.co.uk
Post #1051436 12th Nov 2024 3:44pm
The heater fan slider is not a cable arrangement, it is a four-position sliding switch built into the control panel. Sadly it is an extremely poorly designed and poorly engineered sliding switch. My original one melted and welded itself immobile, and I rebuilt the assembly using parts from a second-hand donor panel.
Perhaps unsurprisingly it is (or at least used to be) a shockingly expensive part as well.
Post #1051441 12th Nov 2024 4:30pm
