Home > Maintenance & Modifications > Led headlights - cheap but legal?
JackNorris
Hi all
Looking to improve my lighting and the fest step is to change headlights.
Now I know eBay have a mixture of £30 a set jobbies but I also know that the likelihood of them being legit is slim
I also know that wipac etc do sets for a lot more
Is there anything in the middle? I have seen SP do a set around £150 but see mixed reviews
Thanks
Post #1051380 11th Nov 2024 11:38pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Please don't.
https://media.rac.co.uk/pressreleases/a-gl...se-3296130
I have been saying this for years. The arms race for ever more powerful headlights is great for the driver but bad for everyone else and even the legit lights with correct adjustment and beam pattern are a problem before you even encounter the myriad of substandard and badly installed aftermarket conversions.
Post #1051398 12th Nov 2024 9:44am
Bluest
I just don't think you can go too cheap with these things. It takes effort and expertise to design an LED headlight with a good beam and is tough and durable. The cheapest I would go with would probably be these https://ore4x4.co.uk/product-category/ltprtz/headlights/
I've got the Truck Lites ones (not cheap and properly certified) and the MOT guy still moans at me about the beam every year because it doesn't have the kick up to the left so is hard to check on his machine. It still passes though. I fully intend to go back to halogen in the future anyway, as I'm not convinced they are actually that much better on dipped beam, it's the whiteness of the light fools you into thinking its brighter. 2007 110 TDCi Station Wagon XS
Post #1051407 12th Nov 2024 11:07am
Mdm
you have a couple of choices.
cheap non road legal ebay specials..only fit for off road use or the bin
clear wipacs ( other brands available) with a range of better bulbs and perhaps a red bison type upgraded wiring loom to feed them. led bulbs can and do work if you buy a good set and will pass mot if the beam pattern is correct etc. i know as u have just done some testing with our local mot man.
or buy led headlights. the britpart bearmach allmakes ones are good and last well.
the nolden,trucklite, stedi or jw speakers all work well.
i run jws ones without issue for many years now
Post #1051409 12th Nov 2024 11:39am
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
I Like Old Skool wrote:
Please don't.
I have to agree with this. 2004 Defender 90 Td5 CSW
2002 Discovery 2 td5 GS (gone)
1994 Defender 90 300Tdi CSW (gone)
Post #1051457 12th Nov 2024 5:59pm
34064
United Kingdom 2003 Defender 110 Td5 HT Alaska White
I was gifted a set of the SP panels ones by my wife a couple of years ago they are pretty good no kick up which is good for driving in EU I guess they are properly adjusted though still know where near as bright as some new cars out there where you can get x rayed by them 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784
Post #1051500 12th Nov 2024 8:39pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I really like the sealed beam led holley retrobrights. Think they are lhd only tho :/ 1953 80"
1987 mini city e
2011 90"
Post #1051511 12th Nov 2024 9:23pm
I Like Old Skool
34064 wrote:
[No]where near as bright as some new cars out there where you can get x rayed by them
I have given up cursing the cars that come up behind me and silhouette me in sharp contrast on my sun visor. It's as clear as the outline on my sun visor that around 5-10% of the cars on the road are running unsuitable lights, and that is in a tall Land Rover, god knows how the drivers of 'normal' height vehicles suffer?
Post #1051530 12th Nov 2024 10:15pm
34064
It's horrible I drive my golf across the new forest for my commute and it gets lit up inside by even normal height cars with these ultra bright lights not pleasant at all 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Post #1051540 12th Nov 2024 11:45pm
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
Please don't.
Agree with that. Some of the rear lights are dazzling too when braking. 1983 110 automatic OM606
Post #1051552 13th Nov 2024 7:38am
Bluest
The DfT are currently undertaking research to understand why the modern legally compliant headlights are generating so many complaints. Don't expect a quick resolution, but I imagine there'll be some regulation change in the future. 2007 110 TDCi Station Wagon XS
Post #1051559 13th Nov 2024 8:40am
mini Anaconda
I have standard headlights with some Wipac spotlights on my A bar wired into high beam and this setup is more than sufficient.
The dazzle from aftermarket / cheap LEDs is horrible, never mind all the modern cars with bright lights. BORG - Bucks & Oxon 4x4 Response Group
Post #1051587 13th Nov 2024 12:59pm
