Home > Td5 > Dead gauges.
4RF RDS
Dead gauges.
So my blower for my OE AC stopped working and along with it my speedo, fuel and coolant gauges. No fuses blown, all relays test well. Fuel is all the way to empty yet a half tank of diesel is in there. The coolant temp gauge does not move at all, neither does speedo. All gauge back lit lights work properly. Any ideas where else to look? Ima bit frustrated I so gave up and will have at er tomorrow.🤷‍♂️
Cheers 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #1051366 11th Nov 2024 10:32pm
landy andy
Think fuse 12 10amp and fuse 15 5amp, are connected to the two systems. I’d start by double checking them and make sure you have the same on both sides of each fuse.
Post #1051372 11th Nov 2024 10:55pm
4RF RDS
Strangely it turns out the fuse was 8 (rear wiper) it was intermittently blown, as in working then not. For some reason that blew and caused my gauges to stop working 🤷‍♂️ all good now! Thumbs Up
Odd! 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #1051448 12th Nov 2024 6:17pm
NickMc
Earth header beside expansion bottle.
Post #1051453 12th Nov 2024 6:38pm
4RF RDS
Thanks, checked that and its uber clean, it turned out to be a wonky fuse.
1967 MGB GT
Post #1051454 12th Nov 2024 6:40pm
NickMc
Assumed you’d checked powers and grounds first.
Post #1051790 15th Nov 2024 12:56am
