![]() | Home > Td5 > Dead gauges. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5813 ![]() ![]() |
Think fuse 12 10amp and fuse 15 5amp, are connected to the two systems. I’d start by double checking them and make sure you have the same on both sides of each fuse.
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 962 ![]() ![]() ![]() |
Strangely it turns out the fuse was 8 (rear wiper) it was intermittently blown, as in working then not. For some reason that blew and caused my gauges to stop working 🤷♂️ all good now!
![]() Odd! 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1679 ![]() ![]() ![]() |
Earth header beside expansion bottle.
Thanks, checked that and its uber clean, it turned out to be a wonky fuse.
Cheers 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Assumed you’d checked powers and grounds first.
