Home > Puma (Tdci) > Removed Light Guards - What to do with the holes?
BradleyF
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Havana
Hi all,
I've finally removed the light guards that I have never liked, but this obviously leaves me with 4 unsightly holes each side and as the title says, what should I do with these holes?
I'm thinking getting a workshop to fill them and respray, or is the easiest thing try and buy headlight panels, if the ebay gods provide, and fit those?
Thanks in advance!
Post #1051262 10th Nov 2024 6:41pm
lightning
lt depends on how good the rest of the Defender is. lf it's a clean one, you'll need to fill the holes and spray the panels.
Otherwise blanking grommets in the holes will look alright, particularly if the Defender is a dark colour.
l would always go with the first option unless you can change the panels completely which is obviously the perfect solution.
Post #1051483 12th Nov 2024 8:03pm
miker
I put screws in mine, but it's not exactly a show queen....
Post #1051490 12th Nov 2024 8:19pm
landy andy
I have put black number plate plastic bolts in to the rivnuts on mine.
Post #1051497 12th Nov 2024 8:32pm
Dinnu
Fir trees perhaps?
Replacing front panel is quite a job, and need to drill out spot welds. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1051544 13th Nov 2024 4:24am
Esben Kold
Denmark 2008 Defender 110 Puma 2.4 SW Galway Green
I am in the same situation. Mine was missing when I got the truck and I haven’t gathered myself and fixed it (I was/am not short on issues to tend to). I initially wanted to buy new ones, even though I really do not have any desire to fit them - other than covering the holes. But I could not find any with a distance between the mounting holes that equals the space between the holes in my truck. If it is not to much of an inconvenience you are very welcome to post your fix, when you get it done. Maybe I will try one of the suggested solutions and post a photo.
Thanks anyway
Post #1051635 13th Nov 2024 8:01pm
landy andy
I’ve got the guards if you want them. I ended up binning the rears, and the same will happen to the fronts.
Post #1051636 13th Nov 2024 8:05pm
Esben Kold
That is very nice of you and I do indeed want them. Can you measure the space between the holes? I will gladly pay you for the handling on top of the postage.
Edit: I would like them anyway and just make them fit.
Post #1051637 13th Nov 2024 8:08pm
BradleyF
Its a pretty clean example, and I am an absolute Tart with it so trying to get it looking very tidy.
Am I looking for any half decent bodyshop to fill, or do I need to find someone handy with a TIG
Post #1052068 18th Nov 2024 9:32am
John P
United Kingdom 2012 Defender 90 Puma 2.2 SW Corris Grey
I had the same issue, plus I had the holes at the back from the rear light guards. I also had a little corrosion around the window frame and window blocks. My local bodyshop filled the holes, touched up the whole front end including the window blocks and rear, plus had a new windscreen and seal fitted at the same time. He went into great detail on how the holes were filled, as they cannot just be filled with filler as they will crack later on. Can't remember what he said, but is hasn't cracked yet. All up cost me £1,300, which I was happy with. Car looks so much nicer. Thumbs Up
Post #1052075 18th Nov 2024 11:00am
