![]() | Home > Puma (Tdci) > Rattling Noise and more – Your Thoughts needed? |
irishhawk11 Member Since: 07 Mar 2022 Location: Feldkirch Posts: 10 ![]() ![]() ![]() |
Hey Td4 Owners,
I need your help! After an intense off-road trip in Corsica, my Defender has come back with some damage. While still there, it became clear that the transfer case (VTG) had taken a hit — a loud knocking noise made that obvious right away. When I checked the oil, I found that the thrust washers in the diff had disintegrated, along with noticeable metallic debris. As a result, I had the transfer case overhauled and added a Torsen differential and a larger oil pan. So, the VTG is now back in top condition. I also took the opportunity to replace the gearbox extension (output shaft), a known weak point in the TD4. Unfortunately, even after these measures, things still aren’t running smoothly. I made a recording of the noise and would love to hear your opinions. Here are the main issues ![]() Noises: Two noises are noticeable. One is RPM-dependent, which might point to the wheel bearing. The other is a constant "rattle," especially loud when idling or in a disengaged state. Could it be the clutch? Oil Leak: Oil is leaking from the front differential at the flange. The oil is fresh, and the differential was recently removed, visually inspected, and resealed — everything appeared normal. You'll find pictures and the link to the audio recording in the attachment. Audio Recording: https://drive.google.com/file/d/1EcTMt9Qhk...drive_link My guesses: Clutch? Wheel bearing? Front driveshaft? What do you think? Looking forward to your insights! Best regards, Ben ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Johan_B Member Since: 20 Sep 2024 Location: Gothenburg Posts: 63 ![]() ![]() ![]() |
Was the whining noise RPM dependent? Wheel bearings should be road speed dependent. If RPM dependent I'd say it points to the engine or the auxiliary drive.
(It feels like I'm kicking in an open door given the amount of work you have done already.) From where does the rattle appear? |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 925 ![]() ![]() ![]() |
Clutch rattle is a known thing with HD clutches.
Does it go away when the clutch is disengaged (pushed in)? Earlier model LOF were known for the rattle to take some time to settle in, Mine has taken quite a few thousand miles to stop the rattle / chatter all the time during idle. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest |
I experience vibrations primarily between 1500-2000 rpm, most noticeable in 4th and 5th gear. These vibrations occur mainly when releasing the clutch and accelerating. They feel as if they transfer to the chassis and resemble the sound of a vibrating metal sheet. However, it seems to be improving over time.
@Johan_B Apologies, I used the wrong term earlier; I meant road-speed-dependent whinning. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20726 ![]() ![]() |
Makes me wonder if the spigot bearing being worn might be an issue, with causing friction plate imbalance over bumps and potholes around the time of gear change, that then rattles the springs a lot.
Road surfaces are bad, it’s not surprising things are getting worn a lot. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
I also replaced the spigot bearing. Everything which came in the LOF package.
After a long time (and being at the end of my rope), almost all problems have now been solved – thanks to a Land Rover specialist. Unfortunately, it wasn’t cheap.
Basically, the entire front axle and the rear differential were gone. Here’s a quick overview of what has been replaced:
Rear differential Radius arm bushes New swivel balls and seals New drive shafts Bump stops (were missing, which caused the CV joint to over-rotate) Anti-roll bar replaced …and some other bits and pieces. There’s still a slight humming noise from the front pinion wheel. The bearing looked fine visually – and with loud music, you can’t hear it anyway. 😄 Some vibrations from the new clutch can still be felt through the chassis, but they’re much less than before. The most important thing: the Defender is back on the road! Here are a few pictures: ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 922 ![]() ![]() ![]() |
I had something similar a few weeks back where I thought that The rear O/S wheel bearing was shot. Then I decided that it was a worn drive flange and then I thought it was the rear prop shaft or a problem with the rear dif.
It turned out to be the exhaust vibrating against the front removable chassis cross beam near to the gear box. A quick adjustment of the securing rubbers and all was well... Jim |
