Home > Puma (Tdci) > Rattling Noise and more – Your Thoughts needed?
irishhawk11
Austria 2011 Defender 90 Puma 2.4 HT Santorini Black
Hey Td4 Owners,
I need your help!
After an intense off-road trip in Corsica, my Defender has come back with some damage.
While still there, it became clear that the transfer case (VTG) had taken a hit — a loud knocking noise made that obvious right away. When I checked the oil, I found that the thrust washers in the diff had disintegrated, along with noticeable metallic debris.
As a result, I had the transfer case overhauled and added a Torsen differential and a larger oil pan. So, the VTG is now back in top condition. I also took the opportunity to replace the gearbox extension (output shaft), a known weak point in the TD4.
Unfortunately, even after these measures, things still aren’t running smoothly.
I made a recording of the noise and would love to hear your opinions. Here are the main issues Big Cry :
Noises: Two noises are noticeable. One is RPM-dependent, which might point to the wheel bearing. The other is a constant "rattle," especially loud when idling or in a disengaged state. Could it be the clutch?
Oil Leak: Oil is leaking from the front differential at the flange. The oil is fresh, and the differential was recently removed, visually inspected, and resealed — everything appeared normal.
You'll find pictures and the link to the audio recording in the attachment.
Audio Recording: https://drive.google.com/file/d/1EcTMt9Qhk...drive_link
My guesses:
Clutch?
Wheel bearing?
Front driveshaft?
What do you think? Looking forward to your insights!
Best regards,
Ben
Post #1050811 5th Nov 2024 4:26pm
irishhawk11
New Status
For those who might find it interesting...
I have installed two new propshafts, clutch, slave cylinder, bleed pipe & valve, spigot bearing.
The outcome:
Rattle noise:
The rattling sound when in idle (clutch released and in neutral) has disappered. In the old clutch one of the small springs had broken and the big torsion springs were rattling, not all, but 3 out of 4. Thus I have more vehicle vibrations with the new clutch but I geuss this is because the clutch is new. Currently I have only done 80km.
The clonking sound:
With new propshafts from TerraFirma on the front and rear the noise is gone.
Remaining Problem:
Whinning Noise:
I guess a wheel bearing has gone but sometimes I have a rattling and yet I am still not sure where this is coming from.
For those you have seen this post and my find it interesting.
Post #1053004 26th Nov 2024 2:40pm
Johan_B
Sweden 2008 Defender 110 Puma 2.4 CSW Tonga Green
Was the whining noise RPM dependent? Wheel bearings should be road speed dependent. If RPM dependent I'd say it points to the engine or the auxiliary drive.
(It feels like I'm kicking in an open door given the amount of work you have done already.)
From where does the rattle appear?
Post #1053009 26th Nov 2024 4:01pm
Devon-Rover
Clutch rattle is a known thing with HD clutches.
Does it go away when the clutch is disengaged (pushed in)?
Earlier model LOF were known for the rattle to take some time to settle in, Mine has taken quite a few thousand miles to stop the rattle / chatter all the time during idle. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #1053012 26th Nov 2024 4:28pm
irishhawk11
I experience vibrations primarily between 1500-2000 rpm, most noticeable in 4th and 5th gear. These vibrations occur mainly when releasing the clutch and accelerating. They feel as if they transfer to the chassis and resemble the sound of a vibrating metal sheet. However, it seems to be improving over time.
@Johan_B Apologies, I used the wrong term earlier; I meant road-speed-dependent whinning.
Post #1053078 27th Nov 2024 8:25am
Makes me wonder if the spigot bearing being worn might be an issue, with causing friction plate imbalance over bumps and potholes around the time of gear change, that then rattles the springs a lot.
Road surfaces are bad, it’s not surprising things are getting worn a lot. TheThunderRolls🇬🇧🇺🇸
Post #1053107 27th Nov 2024 2:26pm
irishhawk11
I also replaced the spigot bearing. Everything which came in the LOF package.
Post #1053114 27th Nov 2024 4:18pm
irishhawk11
After a long time (and being at the end of my rope), almost all problems have now been solved – thanks to a Land Rover specialist. Unfortunately, it wasn’t cheap.
Basically, the entire front axle and the rear differential were gone.
Here’s a quick overview of what has been replaced:
    Front differential
    Rear differential
    Radius arm bushes
    New swivel balls and seals
    New drive shafts
    Bump stops (were missing, which caused the CV joint to over-rotate)
    Anti-roll bar replaced
…and some other bits and pieces.
There’s still a slight humming noise from the front pinion wheel. The bearing looked fine visually – and with loud music, you can’t hear it anyway. 😄
Some vibrations from the new clutch can still be felt through the chassis, but they’re much less than before.
The most important thing: the Defender is back on the road!
Here are a few pictures:
Post #1063740 24th Mar 2025 12:33pm
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
I had something similar a few weeks back where I thought that The rear O/S wheel bearing was shot. Then I decided that it was a worn drive flange and then I thought it was the rear prop shaft or a problem with the rear dif.
It turned out to be the exhaust vibrating against the front removable chassis cross beam near to the gear box. A quick adjustment of the securing rubbers and all was well...
Jim
Post #1063749 24th Mar 2025 2:06pm
