Home > Td5 > Replacing Headlight Panel |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17556 |
Spot welds too, unfortunately.
Land Rover could have made it so easy but didn't. |
3rd Nov 2024 8:26am |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2955 |
It’s easier to replace the complete front panel
3rd Nov 2024 9:49am |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3471 |
How badly damaged is the panel?
As BW stated, the spot welds need to be drilled. Although never replaced one, I think normal rivet heads replacing the spot welds will foul with the grille panel. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
3rd Nov 2024 11:02am |
Meta87 Member Since: 05 Aug 2022 Location: Innsbruck Posts: 22 |
Oh man, I already anticipated these answers. It could have been easy So I should probably use countersunk rivets.
3rd Nov 2024 12:09pm |
Will@LRW Member Since: 04 May 2019 Location: UK Posts: 191 |
You'll also find that there is a "skirt" on that headlamp panel that holds the inner wheel arch, which needs to be removed from the old panel and added to the new one. There is no part number for this part and it is only available when buying a complete wing. LR Workshop
Find a Defender's history and spec: https://defender.lrworkshop.com |
3rd Nov 2024 9:10pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1661 |
Yes you have to drill the spot welds out. I’ve done a fair few over the years. It depends how fussy you are and you can also use panel adhesive- following the instructions is very important that way though. TIG weld it, Counter sink rivets too, or you can
buy the front panel complete with the headlight mounting panel already attached. I’ve also hammered and pushed a few back out, better to start with it still on the car if it’s a larger bit of damage. |
4th Nov 2024 8:14pm |
Thanks for all the insights. I have the option to get a full replacement wing without the outer panel but it'sa 300 TDI‘s originally. Will it fit on a TD5? The „vent hole“ is obviously missing but this could be easily cutout.
4th Nov 2024 8:23pm |
