![]() | Home > General & Technical (L663) > DRL rear light |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2949 ![]() ![]() |
The lights are automatic and on mine l can only select headlights if l want the sidelights on during the day.
However there's something l discovered. You have to wait for the headlights to automatically turn on, say when you drive under trees. lf you then turn off the headlights, the system will then be manually controlled for the rest of that journey until you turn off the engine. So you can then select sidelights and they will work. You can also select headlights on, auto, or fully off. So you've no lights on at all. |
paul105 Member Since: 04 Oct 2024 Location: Poznań Posts: 2 ![]() ![]() |
Thank You. I know it, but i looking for solution to switch on automaticly DRL on front and rear.
Maybe in IID tool G4 is solution for it? |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1217 ![]() ![]() |
Read BOTH pages of this thread.
https://www.defender2.net/forum/topic89518.html?highlight=drl I have redesigned the rear lamp clusters to give the vehicle 'Rear Day Light Running Lamps' Good Luck |
Brulz Member Since: 07 May 2021 Location: Brescia Posts: 35 ![]() ![]() |
ok....
But is ti possible do it with modding the CCF?? |
No, its a 'hard wire' only.
