Home > General & Technical (L663) > DRL rear light
paul105
Poland
DRL rear light
Dears.
How to switch on rear lights automaticly with DRL front?
I thing about settings used by IID Tool G4
Post #1050478 1st Nov 2024 8:50pm
lightning
The lights are automatic and on mine l can only select headlights if l want the sidelights on during the day.
However there's something l discovered. You have to wait for the headlights to automatically turn on, say when you drive under trees.
lf you then turn off the headlights, the system will then be manually controlled for the rest of that journey until you turn off the engine.
So you can then select sidelights and they will work. You can also select headlights on, auto, or fully off. So you've no lights on at all.
Post #1050486 1st Nov 2024 10:13pm
paul105
Poland
Thank You. I know it, but i looking for solution to switch on automaticly DRL on front and rear.
Maybe in IID tool G4 is solution for it?
Post #1050545 2nd Nov 2024 3:22pm
LR Nuts
Read BOTH pages of this thread.
https://www.defender2.net/forum/topic89518.html?highlight=drl
I have redesigned the rear lamp clusters to give the vehicle 'Rear Day Light Running Lamps'
Good Luck
Post #1050556 2nd Nov 2024 4:31pm
Brulz
Italy
ok....
But is ti possible do it with modding the CCF??
Post #1050682 4th Nov 2024 8:06am
LR Nuts
No, its a 'hard wire' only.
Post #1050704 4th Nov 2024 12:06pm
