Home > Maintenance & Modifications > LR OEM led lights
Page 2 of 2 <12
Fifth Horseman
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
Yes, they are a LOT brighter - for a while after I fitted them I'd keep thinking the brake lights had stuck on when seeing the reflection from signs behind me at night.....
Post #103388 29th Nov 2011 9:12pm
I have LR LEDS on the ICE but I have fitted LED bulbs in the standard lenses on my 90 tdi, work a treat
Post #103418 29th Nov 2011 10:17pm
T1G UP
details please!
Post #103425 29th Nov 2011 10:34pm
T1G UP wrote:
details please!
try this ... http://www.ultraleds.co.uk/automotive-bulb...dbi9df4fs6
Post #103458 30th Nov 2011 8:24am
SteveNorman
Has anyone tried these yet?
http://britpart.com/Accessory.aspx?AccessoryRef=4526
Not sure if they fit std holes, or what they are like.
Regards
Steve
Post #103467 30th Nov 2011 9:43am
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
Hi
Paddocks sells some led lights for LR ... they say in their site that fits all Defenders - some with modification necessary ?! - What modification ? they don't say ... Confused
They're cheaper than LR ones ... But it also has on their list something called Smart Load Device 12v ... anyone know what this is Question
It looks like a nice piece of kit ... Anyone tried them ? Knows anyone who has a set ? Do you think it's worth trying ? They don't have that kit with clear lenses ... Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #103495 30th Nov 2011 11:50am
Dave-H
T1G UP wrote:
what about LED bulbs in standard lenses?
you can get the 360 deg bulbs now so no blind spots
You tried this Tig??
Or has anyone else?
Reason i ask is i've twice bought and returned led stop/tail bulbs because they wouldnt work correctly on my truck Crying or Very sad Anyone had better luck on a Defender? [and got a link to proven bulbs]
You can get halogen 380/1157 stop/tail bulbs now ... anyone tried those? [or got a link to a supplier]? Guns and Landrovers .... anything else is irrelevant.
Post #105433 7th Dec 2011 9:36pm
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
fitted!
Kit arrived from Tim at mobile systems, everything in there that would be needed including extra foam gaskets for the fog and reverse plinths that remain on the vehicle.
All fitted in less than an hour - probably a quicker job if the umming and aching was taken out. New relay fitted and everything worked perfectly first time, so a bit of a first for me with LR lighting.
All lined up nicely using existing holes and cabling so an easy job.
Look very nice in clear lenses and very bright which was what I wanted.
Yes possibly not the cheapest solution but avoided all the will it work or won't it fit/work scenarios so I'm happy.
Might try the led bulbs idea on the older 90 as I want to keep that looking original.
Will post some pics up when I get five mins (and not raining)
DJ 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #105482 8th Dec 2011 9:15am
Guessing another thumbs up for Tim then Thumbs Up
Post #105484 8th Dec 2011 9:22am
T1G UP
Or has anyone else?
was in Halfods and i notice they do these quick reacting indicator, stop tails etc which is what you must be on about. Not tried any yet. I want to keep the standard light fittings for now so an LED bulb upgrades the best option. i'll buy sme and see how we go.
Post #105485 8th Dec 2011 9:30am
noogles
Brunei
Or has anyone else?
I've been using these without any issues
http://www.ebay.com/itm/2-x-Car-Bulb-1157-...3cbeedf942
Post #105526 8th Dec 2011 3:06pm
pjh
If you use LED indicators and replace the relay (rather than using a resistor) what happens if you tow a trailer with conventional bulbs?
Many thanks,
Peter Defender 11MY USW
Post #105562 8th Dec 2011 5:52pm
Use a 60W relay and all will be fine Thumbs Up
Post #105597 8th Dec 2011 7:07pm
Page 2 of 2 <12
