Home > Technical > Rear wiper switch
Zapo
France 1995 Defender 110 300 Tdi CSW Coniston Green
Rear wiper switch
Hello,
Recently when I was traveling in Scotland, I had my long spans modified, that's for context. When the front panel switch cables were modified, to have an easier access, was disconnected the rear wiper switch cables.
The problem is that when I look at the wiring diagram, whether on LRWorkshop or in the technical review, I can't find the right order and placement of the cables. The fuses blow because the connections aren't right. I managed to do it once, but don't ask how, the ON position was on the OFF position and vice versa.
Anyway, I'm calling on your expertise (electricity really isn't my thing), to find out which cables in which colors plug in where. I've attached a photo to make it easier.
I have:
- Green wire
- Green / Red wire
- Brown
- Green / Black wire
Subsidiary question: Is it possible that it's the relay that's blowing the fuse?
Take care
Post #1050148 29th Oct 2024 9:37am
landy andy
Hope this is some help.
Post #1050149 29th Oct 2024 9:44am
Zapo
Thanks for the diagram Andy, unfortunately I'm sucking to read properly electrical diagrams and, if I'm not mistaken, wire's colors seems to being the same Confused
(I have other qualities, at least I think so, but electrical diagrams are not one of them.)
Post #1050156 29th Oct 2024 10:29am
landy andy
Your wire colours don’t look like the drawings I have.
Mine show.
Switch
White + green = power in to washer switch
Black + light green = power out to washer motor.
Black = negative to wiper switch
Black + green = negative out to wiper relay.
Relay.
White + green = relay power. Pin 87, and pin 85
Black + green = negative from switch. Pin 86
Red + green = power out to motor. Pin 30
Brown + light green = live out to park switch. Pin 87a
This is from a late Tdi, Td5 wire diagrams. Yours may be older. If so you will need help from others.
Post #1050161 29th Oct 2024 10:48am
landy andy
Just found older diagrams and will sort out later for you once downloaded and written down.
look to have same colours as you.
Post #1050162 29th Oct 2024 10:54am
landy andy
Do you have numbers on your switch terminals?
Post #1050164 29th Oct 2024 11:00am
landy andy
Black and light green = power to wash motor. Terminal c917
Green = power, to both wash and wipe. Terminal c918 That would be where there is also the black wire joined on the switch terminal.
Brown and light green = power to motor park switch. Terminal c916
Red and light green = power to wiper motor. Terminal c915
Post #1050171 29th Oct 2024 11:27am
Zapo
Cheers Andy, and thank you sincerely for taking the time.
I just have a look, I have numbers but not the one that appears on the diagram. I made you a quick drawing. Instead of ENGLAND - LUCAS, I've 2, 3 and 4 that appear on the switch.
Post #1050194 29th Oct 2024 1:31pm
landy andy
One of the wires of the base part. (Your numbers 2, 3, or 4) is joined to a terminal via black wire to a terminal on the higher part (NEXT to your un numbered terminal. Assume T1) that will want the green wire going to it which is the fused supply for rear wash wipe. Your un numbered terminal next to it wants black and light green going to it which provides power to the washer motor.
So you have 2 terminals remaining (depending on which of yours has black going to it) but think that is terminal 4
Brown and light green to terminal 3
Red and light green to terminal 2
Post #1050199 29th Oct 2024 2:57pm
landy andy
This hopefully makes more sense than my ramble above.
Have I put the black existing wire in correct place?
Post #1050200 29th Oct 2024 3:07pm
Zapo
It work!
Thank you so much Andy!
From a diagram to another one, from a def to another, wire are not always the same colors and it was a massive struggle (at least for me).
Thank you for your efforts and for taking the time to search and explain to me, I wish you a good end of the day, thank you again!
Post #1050203 29th Oct 2024 3:35pm
landy andy
Thank you
I actually enjoyed looking into it a researching something I didn’t know about. I would have sorted it old school with multimeter normally but it’s good to get the brain working
Thumbs Up Thumbs Up
Post #1050205 29th Oct 2024 3:39pm
