![]() | Home > Technical > Rear wiper switch |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5868 ![]() ![]() |
Hope this is some help.
Zapo Member Since: 22 Feb 2023 Location: Basque Country Posts: 15 ![]() ![]() ![]() |
Thanks for the diagram Andy, unfortunately I'm sucking to read properly electrical diagrams and, if I'm not mistaken, wire's colors seems to being the same
![]() (I have other qualities, at least I think so, but electrical diagrams are not one of them.) |
Your wire colours don’t look like the drawings I have.
Mine show. Switch White + green = power in to washer switch Black + light green = power out to washer motor. Black = negative to wiper switch Black + green = negative out to wiper relay. Relay. White + green = relay power. Pin 87, and pin 85 Black + green = negative from switch. Pin 86 Red + green = power out to motor. Pin 30 Brown + light green = live out to park switch. Pin 87a This is from a late Tdi, Td5 wire diagrams. Yours may be older. If so you will need help from others. |
Just found older diagrams and will sort out later for you once downloaded and written down.
look to have same colours as you. |
Do you have numbers on your switch terminals?
Black and light green = power to wash motor. Terminal c917
Green = power, to both wash and wipe. Terminal c918 That would be where there is also the black wire joined on the switch terminal. Brown and light green = power to motor park switch. Terminal c916 Red and light green = power to wiper motor. Terminal c915 ![]() Click image to enlarge |
Cheers Andy, and thank you sincerely for taking the time.
I just have a look, I have numbers but not the one that appears on the diagram. I made you a quick drawing. Instead of ENGLAND - LUCAS, I've 2, 3 and 4 that appear on the switch. ![]() Click image to enlarge |
One of the wires of the base part. (Your numbers 2, 3, or 4) is joined to a terminal via black wire to a terminal on the higher part (NEXT to your un numbered terminal. Assume T1) that will want the green wire going to it which is the fused supply for rear wash wipe. Your un numbered terminal next to it wants black and light green going to it which provides power to the washer motor.
So you have 2 terminals remaining (depending on which of yours has black going to it) but think that is terminal 4 Brown and light green to terminal 3 Red and light green to terminal 2 |
This hopefully makes more sense than my ramble above.
Have I put the black existing wire in correct place? ![]() Click image to enlarge |
It work!
Thank you so much Andy! From a diagram to another one, from a def to another, wire are not always the same colors and it was a massive struggle (at least for me). Thank you for your efforts and for taking the time to search and explain to me, I wish you a good end of the day, thank you again! |
Thank you
I actually enjoyed looking into it a researching something I didn’t know about. I would have sorted it old school with multimeter normally but it’s good to get the brain working ![]() ![]() |
