![]() | Home > General & Technical (L663) > Steel wheels, what wheel nuts? |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1217 ![]() ![]() |
you will need Steel wheel nuts for the steel wheels.
the wheel nuts for alloys are very different. |
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 812 ![]() ![]() |
Thanks. Do you have a link or part number at all? Keep getting hits for a traditional Defender which is a different bolt size I think.
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2949 ![]() ![]() |
l can sell you a set of nuts for the steel wheels, taken off a new Defender, complete with the locking nut/keys and centre caps as well if you want them.
For a lot less than Land Rover will charge you. |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3428 ![]() ![]() |
I bought mine from powerful Uk, as above they ain’t cheap. Same with the plastic hub caps they are a bit steep for what they are. 24MY 90 D250 HSE, Tasman Blue
Crazymind Member Since: 11 Jun 2024 Location: Glasgow Posts: 215 ![]() ![]() |
I think I Have paid in the region of 190 quid for the full OEM set!
However I have bought some aftermarket nuts as well to compare ( 35 quid the full set). If you compare them you immediately notice the lips of the OEM nuts is double the size. That lips holds on to the wheel. The design of the OEM feels more reassuring. If you don’t compare them you will not notice it. I am not engineer and despite I am sure they are overpriced considering the Value of the Defender, 150 quid difference is really not worth to save. If someone with more knowledge could shine a light on this… we might save 150quid next time… |
As l said, l've got a full set for sale including the locking nuts and centre caps for anyone who needs some.
